First, thank you blobber for your advices.
The datas that you gave me are exactly my first setup. (Tx=50 turns 0.5mm and RX= 200 turns 0.15mm).
I put them back into my coil shell and put 3X4.7nf in parallel as RX tank and now, it works !!!
I don't realy understand why cause i didn't do anything else than with my first setup.
I'm not sure but i think cheap china ceramic capacitors don't do the job. I put old ceramic caps from the 70s and now it's fine.
If i can give one advice: For caps, cheaper is not a good choice. Prefer old fashion caps or good quality.
Now, everythin works but i have since few days a sound comming from the HP. It's a 2 HZ click with a constant volume level which stop when the detector circuit works. I changed all the ICs but it's the same. What can do such a sound in the circuit .
I'll try to take a video of the strange sound later ..
