Deepers Detector
  • LDTVN
    Yes, indeed, the calibration instruction would be very appropriate, but there are no oscillograms or instructions for calibration. Therefore, the value of TP6 would be very appropriate.
  • LDTVN
    Here on the face immediately can see that you do not understand anything, and when to you put a particular question you completely avoid it and you can not recognize that you do not know this!
    You will not see that the MFC drew the scheme that you published in post # 91, as well as to the Deepers 7 and Deepers 10.
    And what do you show him the him scheme? He asked that I explain to you the last few posts.
    In post #67 MFC published scheme Deepers 10 and wrote:
    Originally posted by MFC View Post
    All I need now are the potentiometers values to have total full schematics of this PI.
    Hi, I regard you explain, it is possible, but sometimes some components have numbers that not correspond to their values and meaning some factory details. I need the exact information because we are speaking of share true information to the forum members.
    nevertheless The potentiometers, what their values?????????????
  • dbanner
    As for measured value, each detector will be factory calibrated, therefore actual measured resistance of trimmers as they are set will vary slightly from detector to detector. What is needed is setup and calibration instructions.
  • dbanner
    You should be careful, Impetuity will get you nowhere. MFC originally stated that he was mounting deepers 10 board and he did not have values of potentiometer for deepers 10 board, and was asking for pot values for deepers 10. Here I am showing picture original deepers 10 board with pot values for TR6. You come here with impetuity, not realising the answer is staring you in the face.
  • LDTVN
    Are you knowingly abusive?
    MFC and I asked absolutely about the other, I have already drawing for you what is need, but you continue not understand.
    Let's try this: in the potentiometer TR6 there are 3 outputs, which is the resistance between the middle and right output, as well as between the middle and left?
  • dbanner
    My brother, look here
  • LDTVN
    Or maybe you open a book and go through the course of radio electronics before writing a nonsense?
    Because children in the school know that potentiometers can acquire different values, and the schematics shows only the absolute value.
    Once you are so "smart" then you can look at the picture and give the answer what should be instead of the question mark?
  • dbanner
    It is plain as daylight, both schematics clearly say 25K for Tr6, not 0.25k. If they wanted 0.25K then they would have stated 250r as they did with damping resistor(470r). It is logical. Maybe sun doesn't shine where you live.
  • LDTVN
    Now open your eyes, turn on the brain, and maybe then you will realize that the potentiometer value can be 0..25k.
    If you do not understand what is being discussed here and you can not help anything then flooding is not needed.
    There was no important message from you on this topic, only flood.
  • dbanner
    TR6 on schem(deepers10) it says 25k, on deepers 8 says 25K multiturn. the associated components for tl081 are same on both schemes. Anyone with half a brain can figure out values from comparison of various schematics and some simple math. There is quite sufficient information contained in both schematics to fill in some missing values. Do some suduko for practice.
  • LDTVN
    dbanner you do not understand the essence. Everyone has seen this scheme, and there are many differences in the item's values from Deepers 10. And there are no exact potentiometers values on it. For example, tell me what value have potentiometer TR6, 1k or 15k? How to adjust it correctly?
  • dbanner
    Deepers 8 with pot values
  • LDTVN
    Please Speak about detectors and electronics desings. This thread is for interchange information and new ideas , not for fighting, this don't resolve nothing. I told before that now are mounting a Deepers 10 board and maybe need to put potentiometers values from Deepers X5 because I dont have this info for the Deep 10DD sch.
    MFC absolutely agree with you.
    Tell me please, you make your board? Or you will do the same as in the original?
    You have a photo inside Deepers X5? What's the difference with Deepers 10DD?
  • MFC
  • kt315
    about you. crazy idiots in Russia had been keeped 100 years ahead.
