Pinpointer with discrimination "Cat-FM" on ATMega328P
Hi friend,Originally posted by MartyJ1963 View Post@Walkman,,,,,What size wire did you use for your 2.2MH pinpointer coil please? I am just completing your layout to try the 1.5.2 Hex file. The coil I made for my first pinpointer was 2.9MH with 0.25mm copper enamelled wire. I have 0.25mm, 0.18mm available to use. Thanks, Regards, Marty.
I use 0,25mm enamelled copper wire and coil capacity 2,2mH
lolOriginally posted by MartyJ1963 View PostSpelling mistake! Easily done,,,Lol,,,2.9mh! Regards, Marty.
I knew that but details are important.
You actually what to have 2.9mH. lower case m = milli (1/1000), H is capital since it is a Proper name, Joseph Henry.
https://en.wikipedia.org/wiki/Henry_(unit).
@Void118 do you plan to release the source code? even if it's written in C I can work / customize it
Thanks for the layout Useus. @Void118, have you built your new prototype yet? Looking forward to your test results. Regards, Marty.
here is my pcb, I still have to test it, it will arrive in two weeks I thinkOriginally posted by MartyJ1963 View PostHi Guys, Are there any layouts available for these 2 pcbs? Thanks, Marty
remember
no battery charge status
no leds
no vibro
+5V buzzer (PAC-1205 or equivalent)
for Voltage regulator i use AN78N05 but you can use 7805CV or any TO-220 (100ma min) regulators, if you use 78l05 (TO-92) remember that in and out are reversed
cat.rar
My design, according to schematic preliminary, size 19.4x41.1mmOriginally posted by useus View Postthis is my pcb design, i didn't use ADC, leds and vibro by choice. the pcb is 23x90mm
power supply circuit in the upper part of the pcb, everything else in the lower part.
both sides gnd fill
[ATTACH]55334[/ATTACH]
Ok Marty, It will be two options, vibro motor option and battery(6F22) life checking, I think device will be tell user when battery discharged and I will add new modes, sound alarm, LED + vibro, Led + sound, only vibro and all together.Originally posted by MartyJ1963 View PostHi Void118. It looks good! I am looking forward to seeing the new Revision on your you tube channel when you have assembled and tested it. I like the addition of the Vibro motor. Thanks for a great project! Regards, Marty.
Marty, I didn't post new version yet but I can show you preliminary version.Originally posted by MartyJ1963 View Post@Void118 and @Useus,,,Nice work guys,,,It's good to see the new additions to the layout and the good progress this project making! Still, no one mentioned anything about a Vibro motor or where to attach it on the pcb? Thanks, Marty.
Now I am waiting for PCB from EasyEDA manufactorer.
