TL12000
  • #46
ID:	362895Click image for larger version
    • #47
      Originally posted by deltapulse View Post
      [ATTACH]57253[/ATTACH][ATTACH]57252[/ATTACH]tl12000
      Is this PCB true or working ?
      • #48
        true
        • #49
          Hi friends
          TL12000 new working PCB with iron discrimination
          https://youtu.be/fMHKAIVjD-8
          • #50
            Originally posted by Asanka Sanjeewa View Post
            Hi friends
            Iron discrimination?
            I must have missed something in that video, despite watching it twice.
            The pliers gave a strong audio response, and were definitely not rejected.
            • #51
              Here the video when it tune for iron discrimination
              https://youtu.be/axOmFrShj_I
              • #52
                Its really funny. This manipulation of the threshold will cancel the iron and cancel with it gold and copper, or at least reduce the sensitivity distance
                • #53
                  This is good detector. I wonder how it reacts to iron sand, if someone has test it please upload. Thanks
                  • #54
                    Does anyone know his original setup parameters? Frequency and Pulse Width
                    • #55
                      check-out first page post #8 here. There are attached screen shots about frequency & pulse width.
                      • #56
                        Hi Forum,
                        here a redrawn TL12000 schematic based on several different circuit diagrams and actual PCBs from the Internet.
                        GeoMax
                        • #57
                          can you please upload the full layout file here, maybe zip container THX
                          • #58
                            hello friend tl12000 is a very good detector that detect a 24mm coin in 40 cm i searched the net for a true schematic but no luck .
                            som one give me a device and i decide to drawn a good schematic for you guys .. this is double checked and 100 working shematic. please somone make a good layout file from this thanks ..​
                            • #59
                              this is the device and pcb image
                              • #60
                                I had a quick look at your hand drawing and see already some problems. The connected R=330Ohm across pin 1 & 3 of the voltage regulator LM7809 is very doubtfull. Also the capacitor "100mKt" at the first 555 timer is not a capacitor value.
