Tx 0.50 /0.97 mh/ 440nf/7.70 khz
rx 0.28/15.30 mh/10 nf (rx test NOT ac18-30-40 ac ml volt -test ferrit+cu+sil+fe+gold ....)
tx folya rx folya GND -12 volt akü (1.2ampers 12volt)
Serbian "Most Wanted"
Hvala Ivice na pomoci.
Thank's Ivica for help.
I didn't tried to much experiment's here, this is my first smw (Serbian Cezar or Caesar).
I just tried many method's for coil wireing, and this one which i wrote work's best for me. Rock stable, exelent disc.
Also, about ic's. LF444 work's too, but like Ivconic said, the best and cheapest in this machine is LF347.
One more thing, for sens pot, serial resistor (100 - 330R) for my machine i found 200R fit the best. Sens can go near maximum, maybe 97% of pot turn before start to chatering.
What i understand here is the best point of performance when Resonance Frequency of TX at 7khz?Originally posted by ivconic View PostYes that's the one checked and 100% good.
I will repeat again here; for top performances is better to use LF347 and NOT TL084, 064 or 074.
Besides; use ic sockets and make compare, you will see significant differences in behavior.
SMW is tolerant towards various coils, it's only important to match TX cap with coil.
For 1mH TX coil i am using 470nF +47nF in parallel, giving 517nF.
In "original" setup 2.2-2.35mH is inductance of TX coil, than 220nF is used in parallel with it.
I guess if you try more precise and add/subtract more small capacitances; most probably you can achieve bit better performances.
Cheers!
thank's CDIOriginally posted by CDI View PostHi totob, my pcb version is from ivconic, with 555 timer.
Coil parameters i can tell only for RX, cause TX is finished long time ago, inuctance is 1.03mH, resistance 3.4 ohm. Not remember how many turns and wire diameter, but somewhere between 0.45 and 0.55.
RX 175 turns, 0.25 wire, resistance 30.8 ohm, 15.09mH.
TX capacitor 480n, RX 62n.
Similiar coil parameters like Minelab Musketeer coil.
Yes that's the one checked and 100% good.Originally posted by CDI View PostHere is pcb with pot's.
Cheers!
Hi totob, my pcb version is from ivconic, with 555 timer.Originally posted by totob View Postgood resalt CDI
What is the version you build?
can you put a pic of your circuit board
and coil informations (diametre turns & inductance)?
good resalt CDIOriginally posted by CDI View PostI finished my smw, i got average depth, about 36 cm for 1 eoro coin. Good thing is that the detector is rock stabile, no instability in room beetwen wifi router and power sources in my house.
Discrimination is near perfect, hot rock fully rejected, ferite rod and nails. Here is my connection for search coil, from head to pcb.
All wires going separate from search head, at the and of cable ( in connector) shield for TX going togheter with TX minus, the same thing with RX.
Red wires are hot connection's, green are minus, and violet is shield.
[ATTACH]34614[/ATTACH]
Never tryed this method, cause i never used coaxial cable(but i will try next time)Originally posted by sinclairuser View Postbasically some detectors can have all there shield connections to one wire or even the braided shield wire if coax is used, this design needs separate wires for tx shield and rx shield they connect in the detector enclosure to the enclosures shield, separating them can make a noticeable difference when the cable moves around when detecting(falsing), it can help with sensitivity to wet grass too i understand.
so when done this way you need cable with enough wires to keep shields separate untill the enclosure.
If i understand good, we need here 6 wires, right?
TX start
TX end
RX start
RX end
TX shield
RX shield
All this is clear, but when we separate shield's from both coil's in search head, they are not separated in pcb. I wanna say, they must be togheter in only one hole on pcb.
Dont undestand me wrong. Just my opinition.
basically some detectors can have all there shield connections to one wire or even the braided shield wire if coax is used, this design needs separate wires for tx shield and rx shield they connect in the detector enclosure to the enclosures shield, separating them can make a noticeable difference when the cable moves around when detecting(falsing), it can help with sensitivity to wet grass too i understand.Originally posted by CDI View PostEverything is clear here, but: "but goes separatelly through cable" (i mean, how we can separate tx and rx shield from only one cable)
My connection:
RX start: separate
RX end: separate
TX start: separate
TX end: separate
Shield: I maked two wires from shield, one for TX and one for RX, they both (wires) going together from search head to cable shield.
This connection work for me.
WM6, did u mean to paint tape insulated coil?Originally posted by WM6 View PostWhy not? You can pot coil housing in two layers.
First layer painted with graphite (with assured ground contact too of course).
You can also paint isolated RX coil (alone or additionally to mentioned two layer) with graphite shielding.
