Serbian "Most Wanted"
  • Asanka Sanjeewa
    Dear my friend,
    Here the photos, if you want discriminate important think is coil mH value. if you made many many size coil you need to select tx 1 mH and rx 14-15 mH. HERE THE CHANGED RESISTORS
    PUT TWO RESISTORS 1K5 FOR 1K8
    2K7 FOR 2K2
    1M FOR 1M3
    DO NOT USE RX 22NF CAPACITOR
    sorry my coil is 40 cm *22 cm [one coil part ]Click image for larger version
ID:	361346Click image for larger version
ID:	361347Click image for larger version
ID:	361348Click image for larger version
ID:	361349Click image for larger version
    Originally posted by Ruben2000 View Post
    Hi Asanka.
    Could you share the mold of your large coil so that you can build one just like it?
    I would also like to know what resistors you have changed or what changes you have made and what capacitors you used to tune.
    I also asked cnckecgo for help and nothing!
  • Ruben2000
    [QUOTE = hooby life; 288028] Hola rubun2000
    ?Cu?l es la especificaci?n de su bobina?
    Tx 1 mh rx 14,75 mh
    Frecuencia aproximadamente 7,5 khz [/ QUOTE]
    Hello hooby life.
    This can also help you.https://www.geotech1.com/forums/atta...8&d=1614119402
  • Ruben2000
    I am going to have to build a new coil.
  • Ruben2000
    Any suggestions would be welcome!!
  • Ruben2000
    These are the measurements of my coil with my new instrument. And that must be the problem for which it does not discriminate.Click image for larger version
ID:	361343Click image for larger version
ID:	361344Click image for larger version
ID:	361341Click image for larger version
ID:	361342Click image for larger version
  • Ruben2000
    Originally posted by cnckecgo View Post
    Tx 1 MH rx 14.75 mh
    does not pierce into the ground I've tried
    Asenka no one helps me double tone smw 555
    Hello hooby life.
    My DD 27cm coil, TGSL mold I built it with the specifications of:
    Tx 1mH
    Rx 15mH
    And approximate frequency of 7.3Khz.
    I made this coil with an inductance meter that I built, with these specs:
    Tx = 43 turns, 0.45mm, 3ohm, 1.013mH
    Rx = 161 turns, 0.25mm, 37.2 ohm, 14.948mH.
    C1 = 68 nF
    C6 = 47O nF
    At that time I did not have an instrument to measure inductance, but now I have received my instrument purchased from Aliexpress and I have measured my coil and it measures very differently than described above.
  • Ruben2000
    Tx 1 MH rx 14.75 mh
    It is fine that others do not care but you do not have to be the same as them.
    That is why all knowledge senpiedeb along the way !!!!
  • Ruben2000
    Originally posted by Asanka Sanjeewa View Post
    I made SMW metal detector follow your schematic. I change someresistors' values . I use 40 cm-35 big coil using PVC conduit pipe. no shild. TX 1mH ( 0.45 mm coil) and RX 15 mH (0.25 mm coil) It can detect ladies big ring at 60 cm distance with full iron discrimination ( in this moment it fully rejected medium piece of iron) I expected helpfrom cnckecgo. But unfortunately he did not help me. But you help me. You are very kind man brother .Thank you brother. I made many many detectors . But my English vocabulary and knowledge is not enough to advice for other members
    Hi Asanka.
  • cnckecgo
    Tx 1 MH rx 14.75 mh
  • hooby life
    Hi rubun2000
    What is your coil specification ?
    Tx 1mh rx 14.75 mh
    Frequency about 7.5 khz
  • Asanka Sanjeewa
    I think I'm going to open a new thread and I'm going to build my SMW version 3 and anyone who wants to help will be appreciated for your help; the problem is that I know nothing or almost nothing about how MD works. Or contact someone to help me. I hope to be successful !!!
  • Ruben2000
  • Ruben2000
    I wanted someone to help me as to why my SMW does not discriminate but it is seen that there is no one who really helps !!!!!
  • Ruben2000
    [QUOTE = zakari; 287979] hola a todos
    ruben2000 y sbaio1 el archivo 145.rar tiene alg?n error que no est? de acuerdo con el esquema smw3
    cu?l es el correcto? Archivo pcb lay o esquema?
    Mejor relaci?n
    Zakari [/ QUOTE]
    Hi, zakari, here are the files I have from SMW3, I haven't built it yet. I hope you find it useful.Click image for larger version
ID:	361333Click image for larger version
ID:	361334Click image for larger version
ID:	361335SMW_3_0_5.pdfSMW_v3.rarClick image for larger version
  • zakari
    hi all
    ruben2000 and sbaio1 the 145.rar file has some error that is not according the smw3 schematic
    which one is the correct?pcb lay file or schematic??
    best regard
    zakari
