Serbian "Most Wanted"
  • Emersonpaz
    Hello friend, I will follow according to Ivconic's specifications
    The TX coil inductance can range from 1mH to 2.2mH and resistance from 2.5 to 3.5 ohms.
    In the case of 1mH; the parallel capacitor is 474 + 473 in parallel.
    In the case of 2.2mH; the parallel capacitor is 224.
    RX = 160 windings, 0.27 mm wire
    TX = 70-75 windings, 0.45 mm wire
    In this case, the TX parallel capacitor is 220nF.
  • gurdal
    Originally posted by Emersonpaz View Post
    starting SMW
    hello master Emersonpaz;
    smw detector what stage are you at?
    What should be the coil resistance, inductance and frequency values?
    Best regards
    Gurdal
  • Emersonpaz
    does anyone know if there are any Aliexpress DD coils that can be used in SMW?
  • MartyJ1963
    Looking forward to the results Emersonpaz. Regards, Marty
  • Ruben2000
    starting SMW
    Good PCB !!!!
  • Emersonpaz
    starting SMW
  • Ruben2000
    Details of my DD 27 cm coil. TGSL model.
    TX = 45 turns = 0.511 mm.
    RX = 171 Turns = 0.286mm.
  • Ruben2000
    This is my new coil with the inductance and ohms measurements. [ATTACH] 55193 [/ ATTACH] [ATTACH] 55194 [/ ATTACH] [ATTACH] 55195 [/ ATTACH] [ATTACH] 55196 [/ ATTACH]
  • Ruben2000
    Originally posted by Asanka Sanjeewa View Post
    Hi ruben2000, It is difficult to explain , sorry friend
    Thanks anyway friend Asanka.
    I am going to do the null of my coils; I do it in the same way as for the TGSL, measuring on pin 8 of the LF347 in the millivolt range; the goal is to get the lowest millivolts by moving one of the coils, this is where the best null is. If I am wrong in my explanation, please have someone clarify it for me.
  • Asanka Sanjeewa
    Originally posted by Ruben2000 View Post
    Hi Asanka,
    What do you mean by balancing the coils well and having a good null?
    Isn't equilibrium and null the same?
    Could you explain that to me in more detail?
    Sorry for asking you this but I don't know much about IB MD.
  • Ruben2000
    Hi Asanka,
  • Asanka Sanjeewa
    Hello zakari and Ruben 2000
    smw is deeper machine among all IB metal detectors. But discrimination is not good. If you want to good discrimination you need to make admiral metal detector. It's simple and cheap home made project. I use ruben's share PCB version. I t is good and super discrimination than other PCB version.some pcb version are not good. also i did not use RX capacitor. When i remove RX capacitor detector works well. Ruben2000 your coil induction value correct. I think problem is your pcb version or unbalancing coil. If you want good work IB md you need to good coil balancing and check the null point. I did not use coil pattern and coil cover because my coil is big.I made equiangled square coil cover using PVC conduit tube and bends. also not shield it.not ground test yet. i made it as a temporary coil because how to work to search this PCB pattern. Here the my coil pattern. It is simillar Russian volksturm coil pattern. Happy huntingClick image for larger version
  • Ruben2000
    Dear my friend,
    Here the photos, if you want discriminate important think is coil mH value. if you made many many size coil you need to select tx 1 mH and rx 14-15 mH. HERE THE CHANGED RESISTORS
    PUT TWO RESISTORS 1K5 FOR 1K8
    2K7 FOR 2K2
    1M FOR 1M3
    DO NOT USE RX 22NF CAPACITOR
    sorry my coil is 40 cm *22 cm [one coil part ][ATTACH]55147[/ATTACH][ATTACH]55148[/ATTACH][ATTACH]55149[/ATTACH][ATTACH]55150[/ATTACH][ATTACH]55151[/ATTACH]
    Hello Asanka, that of putting a bridge instead of C1 if the detector works?
    I have never tasted it that way !!
    I will do tests after I finish building my new coil.
    Thanks for the details!!!
  • zakari
    hi asanka
    what kind coil did you used
    can you explain about tx and rx coils and shapes
    best regard
    zakari
  • Asanka Sanjeewa
    okay brother, i will try to help you , please tell me which thik wire [swg gauge ] did you use for TX and RX COIL and did you remove or change resistors and capacitors ? Also did you use this PCB pattern, Am i correct ?Click image for larger version
    Originally posted by cnckecgo View Post
    Tx 1 MH rx 14.75 mh
    does not pierce into the ground I've tried
    Asenka no one helps me double tone smw 555
