Serbian "Most Wanted"
  • I guess it is 1M3 made from 2 other resistors..
      Probably yes, but with so long pins provided?
      • Hello Friends,
        No…no…. not a secret modification, only lazy me…
        I made a error in the colors from the 4k7 resistor. The one on the pcb is 47k !! look at the colors. Have not removed the wrong 47k but fixt a 1k on top of it. The near 22N cap is also wrong must be 10N (thanks Nakky).
        Best regards.
        Ap
        one resistor 4k7 one resistor 47k look close......
        • My pcb works fine I just tried it with 45sm DD Exelerator.7.05khz 1 euro about 35sm in the air.And there was a lot of interference at home.Now I will make DD27 sm and try it.
          • Originally posted by Pompey View Post
            Hello dear friend
            Please give me information produced coils for 36 or 45 cm smw
            Total Rounds score and wire ....
            With respect
            mesyna
            • ApBerg add those 2 caps to hear the differences in audio!
              10nf beetwen C and E. 1uF beetwen B and "-".
              You will be amazed! Simillar to "bell" at Garrett GTI2500!
              Regards!
              • Please give me information produced coils for 36 or 45 cm smw
                With respect
                mesyna
                • please help me for build smw coil 36 cm or 45cm?
                  • Originally posted by mesy64 View Post
                    First to get dressed as befits the Persian woman then ask.
                    Answer is: maintain the same value of TX and RX inductance no matter of coil diameter. You can do some corrections according TX and RX resistance too.
                    So, buy L-meter and training how to use it.
                    • metaldetector107.....
                        maybe better to be fataldetector107
                        • She is a real woman,with a hole in her hand.
                          And sing the song give me,give me,give me.
                          Nakky
                          • HELLO IVCONIC AND FREINDS
                            I built the circuit SMW but found some disagreement in the revised schematic and PCB
                            1. Resistance is 1K, but the PCB schematic with 4.7K specified. Which is it correct??
                            2.MAX in this circuit does it do?
                            3. If I can instead of 33 micro farad capacitor Tantalum electrolyte to use?
                            4. LM7805 specified in the schematic, but PCB 7809. Which is it correct? 7805 or 7809? ZENER 4.7V and not the PCB Why??
                            5. Resistance is specified in the schematic but 3.9K is PCB 1.8K.
                            6. BC327 transistor in the schematic, but is in the PCB BC547. Which is it correct? BC547 or C327????
                            7. Lord, I instead of the BD180 transistor transistor BD140 to use??
                            8. The schematic 2.7K specified value for this resistance is 27K but the PCB amount specified. Which is it correct?? 27K or 2.7K????
                            9. I can instead of the IC LF347 IC TL074 USE(REPLACE) ?????
                            Please help me
                            With respect
                            MESYNA
                            • Do everything according to pcb.You can use 33mf electrolite,and TL074,064 or 084 for LF347 ,and BD140 instead of BD180.
                              • Dear Ivconic WM6
                                please for god sake dont judge without prove.
                                i dont know whats wrong with me? have i send a virus? have i said bad words? i didnt make a cime only i asked for help nothing more
                                also nothing wrong with it your better than me on electronic fields//
                                so please friend i treat you all of you like real friends not online friends.
                                u must be the same????
                                best regrads
