Originally posted by ivconic
Thanks for the interesting report.
Those caps are here,(see picture below) and they are important.
I wish i could help about this, but i made the circuit and stopped at beginning of summer, i will continue the work very soon.
Max have made a lot more experiments with it, and hope he will come back soon.Last message from him he was refering problems, and said he will not come here so soon,this was maybe 2 weeks ago.
He also found some offset voltage at U8 and made some changes with connection to 6k8 resistor near U9 pin9 ,but i didn´t made them on PCB as we agreed that although they improved stability they were not so logical.
Max conclusion was that there was probably a small mistake on the diagram somewhere, but a test with real coil would be very interesting, he could not adjust GB to completely ignore iron at some distance and thought it could be from the coil : we don´t know offset at waveforms for sure.
I think there was some other small detail, but i cant remember where right now.
I know that after building it Max carefully checked the PCB many times to find problems,and i immediatley corrected the important mistakes,so last PCB version is updated.
When Max built his version there were no ground plane yet,and he spotted an awfull ground loop too that was inducing voltage, so i made the ground plane version PCB.
At least detection range is very good.Hope we can solve intability problems.
regards,
Fred.
