so you say you used one of the hand drawing which a loating around. Yes they are "almost correct" but only almost... I know of about 4 different SuperScan circuits and all are slightly different. So no wonder... How have you drawn the PCB? What software you are using? The correct way is first to draw a schematic (and run an ERC (electrical rule check)) than convert the schematic into a PCB and than place the compnents within the board outline. After placing the components, you can use either an auto router or you route your PCB by hand. And guess... run after finish routing a DRC (design rule check) on your PCB for errors. Thats the way how to do it. Everything else is not professional. Another tip is DO NOT BELIEVE EVERY CONNECTION YOU SEE IN THE SCHEMATIC IN THE FIRST PLACE. Always question it and check whether it could be correct or not with other similar circuit parts. Check also IC's and transistor for correct PIN connection but you should do it ACCORDING TO THE MANUFACTURERS DATA SHEET ALWAYS. That helps a lot in avoiding errors. In the past 20 years, I have seen so far only a few of hundreds of detector schematics which were 100% confirmed error free.
GeoMax
Superscan PI
Unfortunately, the tips given by experienced people are very few and even misleading. Maybe they spent as much money on super scan pi as I did.It's not weird.
- Likes 1
Hello.Originally posted by GeoMax View PostHi ZOUjiarui,
maybe you could share the schematic you draw and used for your PCB. I do not mean the hand drawn circuit which is uploaded already here in the forum. By the way there are at least 3 different diagrams known to me and maybe more floating around here. It could be possible that you have an error in your drawing. You can not expect that people to trace your PCB to find the problem. That is to much work, but a look at your schematic its easier.
Geo Max
I used this hand-drawn schematic that I uploaded, and it is almost error-free, but some details are not clear.
Hi ZOUjiarui,
Geo Max
Make it again.
Inability to work
Wrong circuit, sound coming from the speaker
I can't get 5V, when I put the transistor in the right place, it goes to 5V, and when I put the chip in and measure the voltage again, it goes back to 7v
I don't know what the problem is with this circuit, it will never produce + 5V
Hello, masters.
I have a question, if I remove the resistor in parallel with RX, will it cause the machine to burn out?
Thank you for your attention!
Thank you.
Even if it doesn't go this deep, I want to make it. It's amazing how deep it is.
I presumed gold bracelet, 1 meter deep for such small and hard target, I think nobody will share knowledge for that. Superscan looking for big target, I think you still don't know about timing. Must learn minipulse first go to that thread. Regards
