  • Originally posted by Emersonpaz View Post
    In the schematic, the diodes described as 85 are BAT85?​
    56 D1 1N4148 Top
    57 D2 1N4148 Top
    58 D3 1N4148 Top
    59 D4 1N4148 Top
    60 D5 1N4148 Top
    61 D6 1N4148 Top
    62 D7 1N4148 Top
    63 D8 1N4148 Top
    64 D9 1N4148 Top
    65 D10 1N4148 Top
    66 D11 BAT85 Top
    67 D12 BAT85 Top
    68 D13 1N4148 Top
    69 D14 1N4148 Top
    70 D15 BAT85 Top
    71 D16 1N4148 Top
    72 D17 9V1 Top
    73 D18 BAT85 Top
    74 D19 BAT85 Top
    75 D20 BAT85 Top​
    • Greetings. I would like to do the GS to search for gold nuggets, from what I have read in this forum it would be necessary to use a DD coil for the natural cancellation of the effect in highly mineralized soils. Any other suggestions?
      • Originally posted by Rafael View Post
        No, a DD coil doesn't work any better for ground. Some Minelab models use a DD in a cancellation mode but that requires special circuitry which the GS does not have.
        • Ok, Carl. Thank You. The TDI is Best with DD for gold nuggets? or GoldScan With Mono Coil?
          • They should both be about the same, and I would use a mono coil with both.
              Can you give me the information about the title, Eduardo?
              Mono coil, 13".
              • Hello everyone, after almost a year I decided to finish Eduardo's GS-5 lite project, and I'll be honest, I found it very good and it works perfectly. Thank you Eduardo for sharing this magnificent project. I made a short video to demonstrate how it works. I'm not using a suitable coil for it, it's the same one I use on the Polish pi.
                https://youtube.com/shorts/Yxub1FWlM...0mg0gLKZBrUV6h
                • Jackpot in the beach
                  https://www.youtube.com/watch?v=kd0XLYMnGlM
                  • Два типа бифилярных катушек
                    Тесла 1. и Купер 2.
                    Click image for larger version  Name:	1549387855_32.jpg Views:	3 Size:	130.1 KB ID:	438969
                    Click image for larger version  Name:	1549387866_1.png Views:	0 Size:	71.4 KB ID:	438970Click image for larger version  Name:	1549387874_2.png Views:	0 Size:	9.3 KB ID:	438971
                    • GS5 LITE
                      https://youtube.com/shorts/ZCw64a4KN...Hw5SRdvph2vNIb
                      • Emersonpaz Good work
                        Which is better metal detector for heavily mineralized soil : GS5 Lite or Delta pulse Sniffer XR71 ?
                          Hello, I hope you’re doing well.
                          Regarding the GS5 circuit you built — does it not require any special components?
                          Do the components need any modifications, or does it work as is?
                            I got my PCBs Click image for larger version
                            Where you get them
                            • Originally posted by Laith View Post
                              Where you get them
                              I had these boards produced at JLCPCB.com using the file that Eduardo1979 posted. The only modification was replacing the LT1114CN with a TL064CN using the Commander Mono Coil 11" coil. The ground adjustment allows for very good elimination of ferrous material.
                              As you can see in the video below, ground is at 50% and distinguishes ferrous material from a gold ring very well.
                              https://youtube.com/shorts/2cm2zIaUB...-M9ZD0aaqaTHXe
                              • Any one can give me Gerber files?
