Surf PI Pro
  • this board 6666 is making and me is about 10x7 cm
    you can get it here
    http://www.geotech1.com/forums/showt...516#post149516
    that is surf pi pro PCB
    • Originally posted by liekwang View Post
      ?the Board shall make the length X width how cm..???
      I guess this is a joke, right?!
      If it isn't, I'm in serious doubt you'll make this MD (or any other) properly. Get all the parts first, and you'll see what I'm writing about. E.g. you can't change IC socket's pin spacing.
      Printing from raster image (JPG, BMP, etc.) inevitably requires trial and error approach. Therefore it's much better to print from vector graphics drawing of PCB layout. As far as I remember, you have Eagle files somewhere at the beginning of this thread...
      Regards!
      Jons
      • in post from ApBerg there is file named 99-68 mm
        that are original dimensions
        I have printed 10 of them and they are OK... used toner transfer for later PCB etching
        it would be best to have vector file PCB but there is no vector file,
        as ApBerg made and save original file in Eagle or whatever format
        there is one other PCB design and that is on this thread
        I don't know what is final design for that PCB
        • ?I have created long pcb file arberg but there is difficulty printing double and end his PCB via a jumper wire of copper in the line up and its my problem there is a shortage in the sensitive gold ring only 9 cm in the air with the coil diameter 23 cm 20lilitan wire 0, 5 mm
          • sdesic
            Thanks for the link its pcb layout
            • ?I can not open zip files because my entry to this forum via mobile jon do you have file type jpg let me I'll edit using coreldraw software to customize components IC greeting from indonesia
                Can you post a picture of your PCB so we can see what version are you building
                here is jpg file for surf pi pro - ApBerg PCB design SURFXX
                • ?Thanks for the layout of her one again I want the top of the Board that there is writing his components let me easy to assemble his thanks
                  • part placement file
                    • Originally posted by sdesic View Post
                      You can easily vectorise a raster image with Corel, Illustrator, or any online free vectoriser, chosen from gazillion of similar ones. Then edit any mistakes, scale, hatch, and print out the result in one of free CAD applications, if you don't have something like AutoCAD or Rhinoceros, of course. (It probably could be done also in Corel or Illustrator, but I'm not so familiar with these two.)
                      Regards!
                      Jons
                      • ?Thanks to his information on jons
                        • Be carefull of the starting resistance of R2
                          • 6666
                            ?I select the R2 3K3
                            • Made another surf pi pro - ApBerg PCB
                              this time I don't have -5V on 7660
                              12V and +5V are OK
                              changed 7660 with one on my working board - it is working
                              it is not problem with 7660
                              what to look for ?
                                Thats ok, you will notice in post #415 R2 is a pot, I have posted some CRO pictures somewhere
                                and if R2 is too low, you wreck the pulse.
