Surf PI Pro
  • I should be able to find the problem.
    • Clarify my mistake
      There's nothing wrong with the circuit. It's working.
      • There is a little problem with my circuit. The irf9640 is a little hot. I added a heat sink.
        • The short distance of the detector is entirely due to the fake chip.
          • I had mistakenly removed the 1k fader and added a lead, which caused the bc517 to burn out. Thankfully, it worked again with the 1k resistor
              • Added a photo of my work
                • Hi ZOUjiarui,
                  I do not see the PCB solder side and don't know how your heatsink is connected (or not connected) to the circuit. But between the MOSFET and the heatsink is an electrical isolation missing. Usually there is a Silicon pad and a srew isolation mount between the MOSFET and heatsink.
                  • See some sample pictures here...
Name:	Heatsink mounting example3.jpg
Name:	Heatsink mounting example2.jpg
Name:	Heatsink mounting example.jpg
                    • If there is no contact with the board, there is no need for insulation between the transistor and the heatsink
                      • 加个微信13970800524
                        • Originally posted by yhl View Post
                          加个微信13970800524
                          English?
                          I doubt many people here use WeChat.
                          • Dear Masters, my Surf Pi PRO could not work on the red soil. It could not be stable on the dry soil wall. It was unable to use. It has been disturbed by red soil, the sensitivity is toned to the smallest, but it is not almost detected.To metal, its effect is better than the simplest pirate PI
                            • Did I not debug it well? Don't know why it's so bad
                              • No, the pirate test is better than it. The translation software misunderstood my meaning, and I don't understand English.:哈哈:
