Hi Aziz,
no problem to use t0 = MOSFET gate switch off – then 'p' has to be adjusted to compensate the flyback pulse width. 'p' may also be influenced slightly by the driving pulse width as long as the pulses are not separated in time.
Yes, fully agreed. The problem is that the guys in the VRM document that you linked in post #531 completely ignore the flyback pulse, and only use the pulse width of the driving pulse to derive their equations.
Again, please read my comments to this in post #545.
Originally posted by Aziz
I mean that you are trying to find "too precise law" . You see , even in the laboratory measurements you find some inaccuracy and inconsistency , but what can you expect on the real ground , in the real field ? Even if you find an ideal law in ideal conditions - in the real field you'll meet some disturbing factors ( temperature , magnetic fields , etc ) that will certainly spoil your ground balance
My point is that if you want a reliability - you cannot demand too high precision , it's a kind of a "natural law"
For example , in "general electronics" I noticed this many times - if some circuit needs too complicated calculations , it's better not to use this circuit . It can work on the bench , but in the field it will fail anyhow . The dilemma is simple - if we have a circuit and some very complicated formula with many variable parameters that describes its behavior , there are only two variants :
