Originally posted by Monolith
View Post
Minelab GPZ 7000
I referenced a post with a comment from Eric Foster, in another thread. He made an brief summary/comment on the information in an old scientific paper. Maybe it could be of use here. I will quote his last few words in that post...
"Note that in this paper there is no need or mention of flyback in the expressions explaining the generation of eddy currents. It is simply the sudden cessation or creation of a magnetic field and the induction effect on a conductive target.
Eric."
http://www.geotech1.com/forums/showthread.php?19940-Pulse-Induction-History-and-Theory&p=165128#post165128
Indeed, the Flyback voltage does not need to appear in the expression. However, it does have a significant role in the process. It is the high voltage that pushes a high current through the coil.
We charge the TX coil.
Then we discharge the TX coil. If we have only a few mOhm resistance in the discharge path, it takes a very long time to discharge the joules in the coil.
With a large damping resistor the Flyback voltage goes high and the discharge time is short.
At present, the practical Mosfet blocking voltage is the limiting factor in this process.
It is interesting that the basic principle of the "innovative TX method" has been in the public domain since about 10 years and was discussed at length on this forum, about 6-7 years ago.
This statement is not correct. The flyback voltage is an artifact, and not relevant to eddy current generation in the target.Originally posted by Monolith View PostIt is the high voltage that pushes a high current through the coil.
For example:
Let's say we have a current established in the TX coil. When the MOSFET turns off, the current in the coil starts to decay. Since the effective resistance across the coil is now much higher, the [flyback] voltage across the coil will also increase. The negative amplitude of the flyback is not due to the current changing polarity (as some people have assumed in the past), since the current remains positive. What's happening is that the coil is no longer acting as a load, but has become a generator (or source), which means that it has a negative impedance. It is the collapsing magnetic field that kicks the target and creates the eddy currents. In other words, it's the coil current decay that is important, not the voltage. The flyback voltage itself doesn't even appear in the equations. The high flyback voltage is not "pushing" any current through the coil. The current is already established, and after switch-off it starts to rapidly decay. The high negative flyback voltage is just an artifact.
It is an old discussion. One could say it depends on how you look at the Flyback and the "kick".Originally posted by Qiaozhi View PostThis statement is not correct. The flyback voltage is an artifact, and not relevant to eddy current generation in the target.
For example:
Here is a simple experiment to show the importance of the high Flyback voltage:
Charge your TX coil.
Short it to ground.
What is the Flyback voltage?
How long does it take for the collapsing magnetic field to decay to 0V?
Try different damping resistors, from low Ohm up to the point of critical damping and measure the decay time.
Now tell us a different way to produce the high di/dt we need for a good "kick" without the high Flyback voltage.
Instead of a resistor, try a constant current sink equal to I/2 and see what happens (I = current in the coil before switch off).Originally posted by Monolith View PostTry different damping resistors, from low Ohm up to the point of critical damping and measure the decay time.
That square current pulse (assuming your scope screenshots show the current) is an interesting challenge to produce. First you need to charge an auxilliary inductor to a current higher than he current you want for the Tx coil, then apply its flyback to the Tx coil (to achieve the high rise time), then maintain that level of current at the Tx coil (short circuit it), then switch off the coil. A while back I've designed a circuit that can just do that.Originally posted by greylourie View PostThe device has some operating modes. High Yield/General/Extra Deep. The scope shots show frequency and duration of tx.
The energy stored in the coil isOriginally posted by Monolith View PostIt is an old discussion. One could say it depends on how you look at the Flyback and the "kick".
The amount of energy is proportional to the square of the current. When the MOSFET is switched off, the coil acts as a current source , not a voltage source. As a consequence, the flyback is an obvious [unwanted] artifact of the collapsing magnetic field. It is a side effect, not the cause.
The energy stored in a capacitor is
In this case the amount of energy is proportional to the square of the voltage. And, when the capacitor is discharged, the current produced is a consequence of the voltage developed across the load. In other words, the capacitor acts like a voltage source.
From your two equations, when driving a coil L of capacitance Cc with current I and a MOSFET whose output capacitance is Co, the maximum flyback voltage is:Originally posted by Qiaozhi View PostThe energy stored in the coil is
I think what you point to, is that our TX coil circuit has inductance as well as capacitance. So, could we review the statement above?Originally posted by Teleno View PostFrom your two equations, when driving a coil L of capacitance Cc with current I and a MOSFET whose output capacitance is Co, the maximum flyback voltage is:
Perfect inductor L = current source
Perfect capacitor C = voltage source
TX coil = L+C =?
Now as I said before, discharge the Tx coil with a current sink of I/2 and see what happens to resonance.Originally posted by Monolith View PostI think what you point to, is that our TX coil circuit has inductance as well as capacitance. So, could we review the statement above?
TX coil = L+C =?
The inductance dominates over the capacitance. Considering the very small capacitance values involved, coupled with the fact that the voltage across the coil during charging is also very small, it is clear that the energy stored in the aforementioned capacitors is miniscule in comparison to the energy stored in the inductor.Originally posted by Monolith View PostI think what you point to, is that our TX coil circuit has inductance as well as capacitance. So, could we review the statement above?
TX coil = L+C =?
At the peak of the flyback, all the energy that was previously stored in the coil gets transferred to the capacitance. Because the latter has such a small value, all that energy implies a very high voltage, as per your formula:Originally posted by Qiaozhi View PostThe inductance dominates over the capacitance. Considering the very small capacitance values involved, coupled with the fact that the voltage across the coil during charging is also very small, it is clear that the energy stored in the aforementioned capacitors is miniscule in comparison to the energy stored in the inductor.=>
. For the same energy, the lower the capacitance the higher the voltage.
That would only be true in the absence of resistive losses, and with no damping resistor present.Originally posted by Teleno View PostAt the peak of the flyback, all the energy that was previously stored in the coil gets transferred to the capacitance. Because the latter has such a small value, all that energy implies a very high voltage, as per your formula:=>
When the MOSFET is switched off, the self-capacitance of the coil plus the output capacitance of the MOSFET look like a temporary short-circuit, and a relatively small amount of energy is transferred from the coil to the capacitance. If you examine the coil current decay after MOSFET switch-off, you will initially see a small drop [kink] in the decay curve. This is caused by the transfer of energy to the parasitic capacitances. Once the flyback voltage reaches its peak, the current in the aforementioned capacitors passes through zero. However, the coil current is still significant (about 65%) at this point, and the coil current is being dissipated only by the damping resistor. After the flyback peak has passed, the parasitic capacitors give back their stored energy (which is still relatively small). So the energy stored in the parasitic capacitance is not the dominant factor, and it is not the flyback voltage that kicks the target.
Teleno, I agree with you here. I will share the simulation with you by email.Originally posted by Teleno View PostAt the peak of the flyback, all the energy that was previously stored in the coil gets transferred to the capacitance. Because the latter has such a small value, all that energy implies a very high voltage, as per your formula:=>
