PiTone-v2-by-Eddy71 Has anyone on here built this ?
ID:	408289 Click image for larger version
    So this is the same schematic as the other pcb only small 30x36mm also has pads added to program on the pcb. I will not make this until I have tested the other PCB the good news is its now in the UK should be delivered very soon
      can someone explain what the in red color highlight TL072 opamp circuit part, does?
        Above I have described and given graphs of the detection voltage of the metal response pulses
          Hi Eddy71,
          thanks for the info. I must have overlooked this.
            Originally posted by David_1 View Post
ID:	407954​I like things drawn a little different, so I redrew Eddies drawing, its almost Identical your thoughts ?
            your drawing contains errors. This is not the same as the original circuit. Some components are missing.
ID:	407947 Click image for larger version
ID:	407948 am I right in thinking these are very similar but with different micros ?
              no they are not similar at all. The PiTone-2 is a much smarter circuit design as the FelezJoo PI.
                your drawing contains errors. The PiTone-2 is a much smarter circuit design.
                So please you noticed I am working to put things right... is there anything you would change ?
                Click image for larger version  Name:	ver2.jpg Views:	0 Size:	297.0 KB ID:	408378
                  if you ask already... I find the original drawn circuit diagram by Eddy71 much more strucktured and pleasant to look at. Maybe it is because I draw my circuit diagrams in a similar manner. But this is my personal preferences only.
                  Which software are you using to draw the circuit? Try Diptrace (www.diptrace.com).... It is easy to use and has nicer schematic symbols.
                    I use Labcenter Porteus have done for too many years to change now yes Eddy's drawing is nice, but my circuit is not quite the same just today I swapped over the two op amps for a better layout.
                    Drawing is something I like to do, I had a second pcb to make, but decided my traces / tracks would be better if I rerouted them, in the end the whole pcb is now new ... LOL
                    but not finished yet
ID:	408391 Click image for larger version
                        Hi David,
                        here some improvement ideas for your PCB.
                        1) Some mounting holes would be nice to have. Or do you fix the PCB with "Siemens air hooks" to the enclosure?
                        2) What about a heatsink for the MOS-Fett?
                        3) The PCB size and orientation of components. What enclosure are you intent to use? Actually before I make a new PCB I think first about which enclosure I want to use and where are my controlls located. Specially potis which needs adustments. The poti you choosed is okay but is it also accessable if the PCB is mounted with in the enclosure?
                        GeoMax
                          Here soome more ideas to improve the circuit board design...
                          4) A text legend of what detector it is and about the PCB version is always nice to have.
                          5) Mounting holes should fit the components. In your PCB design the mounting hole of the Mos-Fet looks a bit off center.
                          6) Tracks and other components are a bit to close to the mounting hole of the Mos-Fet.
                          7) Tracks should not run under the Mos-Fet. At least not on the site where the Mos-Fet is mounted.
                            Hi David,
                            7) Tracks should not run under the Mos-Fet. At least not on the site where the Mos-Fet is mounted.​
                            GeoMax
                            Thanks for the sound advice, normally I would never draw a pcb without first having an enclosure, but I really don't know where this is going to end up... maybe the bin LOL
                            will the mosfet get that hot ? I have never made a metal detector just been around electronics all my life.
                            my main goal was to understand the code, that has been reversed Eddy knows this I have sent him most of what I have done. I am not trying to steal his work or pretended its mine.
                            I admire people willing to share their designs online, I see this whole thread as a way to understand how it works and maybe improve it
ID:	408420 Click image for larger version
ID:	408421 Click image for larger version
                              so its still work in progress, but I ordered them so lets wait and see
                                Hi Eddy71,
                                If you are interested in a more complete description, here I argue with the author of the idea of "Pirate" and explain how the details on the indicated node of the circuit work:
