VLF MD with digital signal processing : Bee-Buzz 1
    I already told you no amplifier ( beyond differential buffer ) is required LOL. With an IB balance the problem is to analyze difference signals ... not an noise / amplification problem.
    It is very important to understand the problem before providing a solution.
    But I do have an ultimate pre-amp joker yet. This is the ultimate-ultra-low-noise pre-amp. It is a masterpiece from someone else and beats everything on the planet.
    • Well ok. The new ultimate joker is really worth to make a breadboard circuit soon.
      I can get below 0.1 µV (rms) pre-amp noise for 200 Hz bandwidth decoded signal at gain of 29. This with a series RX coil resistance of 2 Ohms (the dominating thermal noise source). The input voltage noise density is at 0.226 nV/rtHz, which is very good at low gain.
      No, I won't ever have pre-amp noise problems now. Everything will be quiet - very quiet - soon. Except the EMI of course.
      I am really very impressed about the genuity of the designer of the pre-amp. It is a low-cost KISS masterpiece.
      More details soon..
      • This is it. No op-amp, single NPN/PNP transistors, cheap elcos (need not to be low ESR types), very low cost design. Gain is set to 29 for Rs = 2 Ohm. This is an adapted and arranged version of Richard Lee's Amplifier. Two battery cell operation (2x 1.5V).
        Source: https://www.hifisonix.com/articles/r...e-mc-head-amp/
        Very nice article here:
        https://hifisonix.com/wp-content/upl...tra-MC-Amp.pdf
        Click image for larger version  Name:	Richard-Lee's-Ultra-Low-Noise-AC-Amplifier.png Views:	0 Size:	123.3 KB ID:	435083
        I have added D1 and D2 for protection of the transistors. You never know, what the RX coil can do to the front-end.
        This is really a masterpiece KISS design.
        Cheers,
        • Are you on the Make Amplifiers Great Again team ?
            Yup!
            • Hi all,
              I have put a working LTspice simulation files for your convenience to play with. You can do transient, AC (frequency response) and amplifier noise analysis. Just make the desired command line active and mark the others as comment.
              This common base transistor pair amplifier is acting like a TIA (transimpedance amplifier - current to voltage amplifier). This is what it makes it very very interesting. Watch the current through the signal source. It's voltage drops due to source resistance Rs.
              It's a best finding gadget for decades!
              Fortunately, I have purchased enough transistors ZTX851 and ZTX951 and I will get them very likely tomorrow.
              Cheers,
              • Common-base is generally the better approach to low noise. Here is a CB preamp I was messing with several years ago. It does not require a floating voltage source. I don't recall where I found this but probably an audio application. The values shown are what was used in my last sim.
                  It's the same topology. A bit modified however. You have a buffer (amplifier) and the end of the output to get defined gain regarding output impedance to the next stages.
                  It's a (old and forgotton) moving coil (MC) amplifier.
                  Also very interesting.
                  Thank you Carl.
                    • Hi all,
                      now the real EMI noise at home. Fasten your seat belts please.
                      I have connected an RX coil (L=2.1 mH) to an ultra-low-noise pre-amp of gain 100. The pre-amp does not produce any significant noise. Even with gain of 100. But the sound card does.
                      Let's look at the shorted input of the pre-amp first:
                      Click image for larger version  Name:	NoisefloorlevelG100-Shorted-Input.png Views:	0 Size:	87.3 KB ID:	435117
                      And now with the RX-coil at the pre-amp input:
                      Click image for larger version  Name:	NoisefloorlevelG100-RX-Coil-2.1mH.png Views:	0 Size:	98.4 KB ID:	435118
                      You see, the FFT spectrum rised on almost all regions up to 70 kHz. Above 70 kHz, the ADC of the Sound BlasterX G6 produces more noise so the EMI isn't visible, because the EMI noise is below the noise floor level of the ADC system. There are still regions with low EMI noise (around -110 dB level regions). And regions with bad, really very bad behaviour (all the peaks).
                      You see, that pre-amp gain of 100 is large enough. It should even be lower. Maybe 6 dB lower. This is factor 2. So pre-amp gain up to 50 is ok I think.
                      If we have an IB-mismatch, which produces 10 mV residual signal on the RX coil, this would be at gain 50 500 mV output. Ok, maybe too much. We should take lower gain. Or lowering our IB-mismatch residual RX voltage.
                      Maybe an active cancelling with a cancelling coil (one turn loop over RX coil)? Yes, this could be done very easily. I have done it 15-20 years ago. This is working perfect. Even on a dual frequency detector. But I would lose one output channel and would have half TX power at the end.
                      Anyway, you see the EMI noise (at home), which is causing a lot of headache.
                      Cheers,
                      PS:
                      Next time, let's look the RX coil signal without pre-amp. But with working TX-circuit. I'm sure, we won't need any pre-amp with residual RX voltage up to 500 µV due to IB-mismatch.
                      • Hi all,
                        I have my purchased parts now.
                        The choke L1 in my TX circuit is getting difficult to realise. I haven't found a good coil former yet. I have several plastic coil formers, but they are either too big or too small or I don't get enough number of turns on it. Or I have to use 0.7 mm magnet wire, which increases it's resistance up to 1 Ohm.
                        For the choke L1 it applies, as tight and compact as possible to
                        - achive high inductance with less copper (less turns)
                        - low series resistance to increase power efficiency (by using thick magnet wire)
                        - high mechanical stability to avoid microphonic effect, which will cause electrical and audible noise (in low frequency audible range).
                        Anyway, I will use the single frequency TX for measurements until the choke L1 issue has been solved.
                        Yeah, I will make the Richard Lee's pre-amp soon. It is so nice.
                        • my problem is not a noise but EMI 60 Hz
                          Click image for larger version  Name:	thumb_57533.jpg Views:	0 Size:	4.8 KB ID:	435150​
                            Hi pito,
                            you have to go out field testing. There is no mains hum.
                            We should not have any low frequency mains noise as we are decoding at the much much higher transmit frequencies. Even the multiple harmonics of the mains hum shouldn't be a real problem. You must be doing something wrong. The noise could be other noise source however.
                            • Hi all,
                              well I have connected a TX and a RX coil to my sound card. Pushed the transmit power to almost maximum power and tried to balance the RX coil. Only single frequency at the moment. TX coil is tuned with a capacitor at 27375 Hz resonant frequency. RX coil is not tuned. No pre-amp connected.
                              I could balance the TX and RX in first attempt into the 1/1000 of the ADC input range. This is something in mV region depending on the line-input level ruler. I could probably get it better and lower.
                              RX Phase detection is so much sensitive compared to magnitude. Which is the normal case if you look at the frequency response spectrum at resonance frequency. The phase change is much steeper than the magnitude. If you have a high Q TX coil system (low TX resistance), this is even much more sensitive. But we can do more. Much more.
                              As the RX coil won't be tuned at all with a capacitor in the multi-frequency mode, we really need an amplifier to get more depth and sensitivity. A gain of 50 to 100 is in game again.
                              And guess what? We need an Ultimate-​Ultra-Low-Noise-KISS-Amplifier (UULNKA).
                              Without the pre-amp it would be a nice detector. But with the pre-amp ...
                              I will show you some pics if I have more time.
                              Cheers,
                              • This is it.
                                Click image for larger version  Name:	TX-RX-IB-flatline-no-preamp.png Views:	0 Size:	106.4 KB ID:	435156
                                It got even 5 times better. I could probably get much better with active IB-nulling. Then pre-amp gain of 500 or 1000?
                                Cheers
