Originally posted by Carl-NC
One of the first self oscillating detectors or homodyne ( where the active device ... a valve is an oscillator and mixer ) is this one .. circa 1928
The feedback brings the oscillator just to the point of oscillation which is self synchronised to the incoming carrier. It self mixes the incoming signal and the headphones are the "low pass filter".
when the oscillator was split out to a separate valve it was called a synchrodyne however here the separate oscillator was synchronised to the incoming signal so its still "self mixing".
For some reason that is not clear the IQ demodulator is referred by some today as a homodyne even though it has two mixers and is not "self mixing" ( ie two quadrature phase signals are generated and mixed separately. )
The patents for IQ demods indicate they are a new method with improvements beyond the homodyne method.
So why IQ would be called homodyne does not make historical or actual sense. ( I would call it dfferential phase mod / demodulation )
IQdyne just doesn't quite have a ring to it does it ? LOL ... maybe that is why the term is not used.
However I will note that whereas the homodyne tries to lock to the transmit carrier ... the IQ demodulator LO only has to have nominally the same frequency as the transmit carrier ... this was the whole point and benefit in the case of radio. ( but not MDs )
moodz
