Hi all,
there are obviously some restrictions and limitations in the coil geometry definition. Dilate and contract will not work if the coil has concave and convex structure at the same time.
Best example is the omega coil shown below.
At the bottom part, the connections from the inner to the outher coil are wrong.
This will lead to little inaccuracy in the numeric calculations.
But there is a work-around possible. Define each path individually and build the bundle.
These are soils the the7000 run in locate patch mode will cope with as will the gpx. Also, I am not aware of any 8000 uses finding a deep nugget that the 7000 or gpx could not detect. Most of the outrageous 8000 depth claims are due to hopeless pinpointing as the nugget was in the hole side wall and falls to the bottom the hole when it widened.
