TESORO GOLDEN SABRE
  • erolunall
    Dear Molzar
    Thank You for good photos
    if you sent info about parts (transistors and others) is same or not with shema will be helpfull for all.
    İf you could sent this photo before this thread will be not soo much long
    Best Regards
    Erol Ünal
  • simonbaker
    Thank you for pictures and tests! With some work it should be possible to make exact schematic of original, answer many questions.
    Cheers,
    -SB
  • Molzar
    Hi Friday,
    I have TGS, not lite version. Here are pics..Enjoy
  • Friday
    no problem Molzar.thanks for your warning....
    do you have TGS or TGSL?test seems good..
  • Unregistered
    Guest replied
    Did some air tests with 8" coil.
    Discrimination Mode (Full Sense)
    US 25 cent = 20 cm (Silver)
    US 5 Cent = 22cm
    All Metal Mode may be 1-2 more cm
    Unit becomes a little unstable set at 9 or above on Sense.
    So no surprizes.
    Took apart tonight to have closer look inside. Component values and locations seem to be as per Kurtie100 component layout. Haven't checked every component as yet but did check quite a few and they match perfectly. Solder side of pcb is work of art. Artwork was made by hand (like they did in the 80s) and is very curvy. ICs are Motorola and NatSemi. Sorry I can't post photo but no good camera here. Will post some shots next week. Might be tough to get good shot of component side because of all wiring.
    Also things are not going well here personnally so hobby may take "back chair". But I try to post next week.
    Molzar
  • Unresistered
    Guest replied
    Mistake!!!
    Originally posted by Molzar View Post
    Friday,
    This not correct. Tx should be with 15 nF cap, Freq=14.6kHz
    Inductance seems high but this depends alot on instrument used and method of measure.
    Don't worry to much of inductance just follow recipe for good coils in this tread.
    Molzar
    Friday,
    Sorry for stupid mistake. 15 nF is for Rx!!!!!!
    Molzar
  • simonbaker
    Simon,
    Recieved the orginal beast today. Took a quick look inside and........
    Is just what I had thought previously, pcb looks like almost perfect match for one posted by Kurtie100 on page 1!
    Of course this was just quick peek, will do more thorough analysis soon.
    Molzar
    Super! Hope you can get good pics of both sides of board (exactly straight-on shots, good focus hopefully).
    Much appreciated!
    -SB
  • tiktak
    Molzar.
    Thanks.
    It will be very interesting to see the exact components places and values.
    Can you also make some air depth tests please?
  • Fred
    Simon,
    Molzar
    Hi Molzar
    It will be very interesting to see pictures of the board.Hope you can also let us know about performances, to compare with the homemade one.
    Fred.
  • Molzar
    Simon,
    Molzar
  • simonbaker
    Hi Simon / Tiktak,
    Yes... could be very interesting to take a glance at "original beast". But I not that optimistical there will be any real big difference. I think performance be less than results posted here as handmades I think can be tweaked much higher performance. Is be fun though, may be here by week end. Will keep you informed.
    Molzar
    Lots of questions can be answered... which side of LM7808 are big capacitors, audio driver circuit, feedforward resistor, etc..... fun!
    -SB
  • Molzar
    Originally posted by Friday View Post
    hi...I built this coil.is it right?
    TX: 6 mH akort(same) 20nF frequency: 14.528 kHz
    RX: 7.49 mH akort(same) 15nF frequency: 15.015 kHz
    Regards...
    Friday,
    Molzar
  • Molzar
    Hi Simon / Tiktak,
    Molzar
  • Friday
    Regards...
  • simonbaker
    Molzar.
    Congratulations!
    So we will see whats inside.And what we miss.
    Nice investition.
    At last................
    Wow, excellent! Looking forward to details, photos, etc!
