I have Added some points like
A! ,A2 ,A3 to the shematic.
do you mean A1 must be connectted to Y .
and rest are empty.
TESORO GOLDEN SABRE
Golden Sabre
Hi Ivconic and many thanks for your comments. yes i think i ll do two coils. One for coing shooting and the smaller one for gold hunting.
My circuit is 40% advanced and if i have the time i think it will be ready in a few days and of course i ll post my experiencies.
Best regards
Nelson
Santiago, CHILE >SA
Originally posted by ivconic View PostYes Geo i received it.I already had it...never mind, thank you anyway!
Best regards!
Okantex,
In G.Sabre you have 7808 type regulator giving +8 volts.
Also you have chopper which should generate arround -8 volts theoretically. But,practically
no need to expect "clear" -8 volts from it. It should generate arround -6.xx volts which is
quite enough to run G.Sabre properly.
I am using 12v/1.3Ah battery with my G.Sabre. Audio is consuming some power, but still has no
affects on overall performaces, so you do not have to worry about that.
If you want to use 9v battery, fine..it will work. Due lasting longer you may use 2 of them
in parallel connection.
"...if this detector is good on detecting gold nuggets?..."
Yes. I think it is suitable, although i havent tested it on those. Mostly i tested it on
coins and small items and it is working perfect!
Asuming that you'll have to make smaller coil for nugget hunting. I suggest you to make
4" to 6" coil for that purpose.
Garret ace 250 is good detector but not compareable with G.Sabre at all! No competition!
Best regards!
Okantex,
desoro golden sabre connection
Hi erolunallOriginally posted by erolunall View PostHi İvconic and all
I saw that connection of Y is not shown anywhere.
There are x--w connection all met/disc connection.
Where we will connect Y?
near x--w connection all met/disc or not?
Erol
YES connect near W
Hi İvconic and all
Erol
Hi Ivica.Originally posted by ivconic View PostVcc is +8v, Vdd is -6.xx v
+Batt. is +12v and -Batt. is -12v....which means directly to one and only battery....if used 9 v batt, than same thing...
I am using 12v /1.3Ah accu. to supply G.Sabre....If want to use 9v batts than use it, no problem. To last longer you may use 2 of them connected parallel....- more current, same voltage...
Please did you receive the mail of Eldorado pcb??
Golden sabre question?
Hi Ivconic, i m working on golden sabre project and my question is if this detector is good on detecting gold nuggets?
Mine will be finish in a week or two, so for it i have plan to make a standar coil and also a small one. The idea is to have a machine for gold nugget hunting and coin shooting.
My garret ace 250 is doing very good, but lacks on deep (only 8 inches maximun for a coin) and no sound adjustment. Also cant detect a 1 gram gold nugget.
Your knolegment and experience will be very helpfull to finish this golden sabre projects.
Best regards and congratulations for your big support to metal detectors builders.
Nelson
Extreme good results!!!
I finished packing it in box.Also finished smaller coil and preparing a bit larger.
Both tested.
1cm coin at 36cm with larger coil, absoulute stabile, no drifts,no hums,no false signals!!! Discrimination perfect!
1cm coin at 30cm with smaller coil.........rest same as with larger!
Smaller coil tested on ground. 29cm depth detection of 1cm coin burried in ground! Much better than Musketeer!
" ...if Minelab can do, why dont we?"
I told you...didnt i?
Both coils same inductances; 6.5mH for Rx and 6mH for TX.... (double D)
Larger 26x26cm and smaller 24x13cm (double O coil)
What to say?
I guess i was sort of blind, wasting my time with Classic so far....
This Golden Sabre is perfectly optimized, thats why so good results!
I dare to say that it is much better than Bandido too.
So....thats all so far!
Hi
I did not understand these words.
what do they mean in technically.
in zahori they were connected to battary +9 and-9 .
here you say+8 -6 .what will I do these pins.
I wantted to say.will I use two battaries .one 9v for Vcc and Vdd of audio another 12v battary for other pins of audio and the pcb.
if I use 9v for all will I loss performance.if so I do not want to use 9 volt.if ICs need 12v I will use 12v.in schematic there is tl062 .does not it need 12v as I remember from delta.
and in modified shcmatic there is one 9v.where will I supply it.
will I add 9v battery for these.
Hi Ivconic
or Mr. Lecturer
I have a question.
zahori 's power supply 9 volt .and Vdd and Vcc and all bats go to +9V and -9V.
but inhere goden sabre power supply is 12V.
will bats be +12v ,-12v.
and what will Vdd and Vcc be? 12 or 9.
and what do Vdd and Vcc means .
Hi Max
forgive me for wrong link
Hi Ivconic.
Can you tell me if i can replace BF245C by 2n5484, becuse this transistor is very common here in Chile.
Nelson
Fat fets....Sheesh!
Instead BF245 i used J107. U may use any simillar, look in some charts, find simillar...
No problem, come with questions, but you will not have any problem with this, it will work fine from a start....
Regards!
Hi Leto,Originally posted by Leto View PostHow to overcome poor audio on Golden Sabre?
As I see the problem - sound just needs some amplification,
and it just happens that I have lots of surplus LM388 - 1.5W audio amplifiers.
This IC is obsolite and discontinued but has great charateristics..
supply voltage: 4 - 12 volts
output power: 1.5W / 8 ohm
it adds 20mA to total consumption
minimum external parts
Circuit used is from datasheet (gain - 20x) and it works perfect.
Faintest sounds are well amplified and for close targets
volume control was added.
well done. Simple, easy and functional !
I think that using the optocoupler could avoid problems related to feedback due to current variations...caused by output stage in circuits like bandido that are really sensitive to noise and produce much commutations related to poor supply rejection of overall circuit.
I think that golden don't suffer from that problem so your solution could be the right choice for it.
Pretty nice also the small pcb!
Best regards,
Max
