Many constructors here never left workshop and tested their detectors under real conditions - huge mistake! I bet they will be very disapointed when see how hard is to work with unstable detectors on real soil, in real conditions. Respecting this i always first perform tests on real field than make some conclusions, later post some experiences.... It is not rare to see reports about great "depths" aka distances gained in workshop, on the desk....Huh! Than when tested on the ground.......terrible results - nothing! When grounded good....all of the sudden no depth at all!? If grounding ever possible on those detectors....Heh,heh,heh! Real beauty is one single transistor in TX output....2N2907,BC327 or simillars....and than to make it work calm,stabile and to detect single coin over 30cm....Thats what i call good detector... Bye!
Very true! The real testing in done in the field. It's easy to get fantastic "depth" on the bench in an air test, but outside .... nothing.
In the local detector shop I have seen many demonstrations of the latest detectors. Incredible "depths" in air, but only with sensitivity set at maximum and no discrimination. In practice - unusable.
Only a few detectors can boast good stable operation in real conditions.
for tic tac
hello brother tic tac
messure gauge in wire is not equal=
calibre is not same mm or milesim
30mm or milesim, is not same what cal 30
in you coils is not the messure equal, in ohms, wire cal, of wire in mm
one metre, of thicknes wire, have most resistence in ohms, what one meter of wire not thickness eg' 10 ohms and 6 ohms
thickness wire carry out lees power and produce most inductivity(atraction)
Hi Max, can you post where is R55 on PCB scketch, cause i m not shure what to do. I only know that i must conenect 1M resistor parallel to D12.
Sorry for asking a to basic question.
Nelson
... also using the R55=1M mod accross D12, tested it and works so good....
Here it is ... D12, you have to put resistor in parallel to it.
There isn't any pad for it... you have to solder e.g. on downside of PCB, or on diode's leads on the upperside.
Nelson
Max.
Thanks for starting batteries tread.
Can you told me what were the values for this 12cm OO coil that you have made?
TX=?;RX=?;
wire 0,25 without varnish/0,27 with varnish/
Until I get good suply I will make coils..... ha-ha-ha.
I've explained that all is in Ivconic's posts... read them all.
Max.
TX=?;RX=?;
Max take a look at this; could this be used on TGSL? I am wandering.... Took it from "gradiometer".....??? Already asked KT315 to translate some Russian words about this..."pitanie"...
I think it's a VCO with buffers that directly drive the speaker (probably piezo like in table phones). Buffers are logic gates of 4001 (4x 2 input nor-gates).
Result is a like square-wave at speaker like in some distorting push-pull end-stage.
It's similar to what I meant for a good VCO, with common easy to find (4046) still today and cheap IC (around 60-70 eur-cents).
The interesting part are external components used (cap. and resistor) for selecting the hi-frequency limit.
About previous post...? I dont understand... But for sure i do not suggest strong TX either...To many drawbacks and few benefits..Like i said before; better is to sacrifice some depth due more stabillity on real field.. Many constructors here never left workshop and tested their detectors under real conditions - huge mistake! I bet they will be very disapointed when see how hard is to work with unstable detectors on real soil, in real conditions. Respecting this i always first perform tests on real field than make some conclusions, later post some experiences.... It is not rare to see reports about great "depths" aka distances gained in workshop, on the desk....Huh! Than when tested on the ground.......terrible results - nothing! When grounded good....all of the sudden no depth at all!? If grounding ever possible on those detectors....Heh,heh,heh! Real beauty is one single transistor in TX output....2N2907,BC327 or simillars....and than to make it work calm,stabile and to detect single coin over 30cm....Thats what i call good detector... Bye!
What do you mean by stronger NF signal?
If you mean on that 1M resistor.....it is not only about stronger audio.
Answer is yes, noticeable better sensitivity...
I'm not sure what that NF is... but maybe he means RF signal (at tx coil). The way of getting more depth, pumping e.g. 100Vpp on tx
but then detecting even grass.
