TESORO GOLDEN SABRE
  • liekwang
    ?satdaveuk now I have a problem 22omh resistor near burning me confused 7808 what could cause burning I use mpsa 13 with 0, 8omh 5watt speakers
  • satdaveuk
    Hi Liekwang
    The TLO81 will replace LM308 and work fine.
    On some but not all of the TGSL builds we found the LM308 to be a shade more stable when using the machine out in the field but apart from that they work just fine.
  • fmnotes
    Originally posted by liekwang View Post
    ?I just need to find a replacement for lm308 I have currently TLa081 and ic TL082
    Try it yourself. Evil will not do in the system.
  • liekwang
  • fmnotes
    ?I just can do same TL081 do you think
    Try Believe that temporarily will work, but can in some problems. but yet it can not create a problem..
  • liekwang
    fmnotes
  • liekwang
    ?Spikes can I find TL081 does equal the LM308
  • fmnotes
    What is the best replacement for LM308 ic please I do not get the lm308 ic in my country
    this OP07DP I can replace the lm308.
    the thing is, you can not find the lm308 in OP07DP will be able to find it?
    the NTE 938 best seems
  • paku
    PartNo Replacement Repl. Mfr Type Additional
    LM308National Semiconductor ยท Operational Amplifiers OP77 Analog Devices
    OP02 Analog Devices
    OPA237SINGLE-SUPPLY OPERATIONAL AMPLIFIERS MicroAmplifier Series Burr-Brown
    Legend: Pin-to-Pin Replacement
    Compatible Equivalent
    Functional Equivalent
    Possible Analogue
    http://www.allxref.com/nsc/lm308.htm
    OP77
  • liekwang
  • liekwang
    ?I am in my country can only get his F245 type Fet BF245 not I fear his wrong pin is not the same between BF245 and F245 does in this forum can you please explain
  • paku
    From Silverdog Transistor BC547 b011 Like on this picture
    But From My Country BC547 b113 is that different
  • paku
    This Is A Video Before Damage Happens
    now i get error that's only just long beep
    what is the pin out i need to change
    MY TGSl tone is not working just silent no sound
    so i have try change coil but still same just long beep and silent
    then i pull out the battery then put it back why, i get sound same long beep again
    what is the problem bro
    Before That Error I Have Change BC547 cause the original BC547 From silverdog kit is broken
    so i change Same BC547
  • satdaveuk
    The most common fault for the symptoms your getting is the pinout connections on the fets, different manufactures = different pin out connections, most of us have been there many moons ago.
    Nice job, very similar to my first build.
  • paku
    Now What Is This Problem Any One Can Help Me!
