TESORO GOLDEN SABRE
  • J_Player
    Hi Max,
    There is some confusion because I pasted the wrong LM number. Ivconic was talking about LM308, not LM324.
    The fact is the LM308 is considered a better op amp. It's a precision op amp with specifications a factor of 10 better than FET amps over the same temperature ranges. I would not expect the general purpose TL081 to perform as well. But the real test is in the circuit.
    My opinion is it is worthwhile to spend a little extra money for precision components when they are performing critical functions where an improved overall performance is demonstrated. I wouldn't be concerned if some people call these obsolete. They are readily available in most of the world. Of course, there is nothing wrong with continuing to use the TL081 if that is your preference.
    Best wishes,
    J_P
  • Max
    Originally posted by J_Player View Post
    Hi Ivconic,
    The TL081 is considered a general purpose op amp, while the LM324 is a high end op amp with better precision and temp compensation etc. If you find your circuit works better with the LM324, there are even better op amps you can use instead of the LM324. Try reading this: http://thunting.com/geotech/forums/s...ad.php?t=13407
    Bese wishes,
    J_P
    you have lot of confusion about op. amps.
    Let's correct:
    LM324 is obsolete quad op. amp. ; No good there.
    about the link you provided...
    the LM394 are junction isolated ultra well-matched monolithic NPN transistor pairs with an order of magnitude improvement...
    so matched pairs NPN, not an op. amp.
    Kind regards,
    Max
  • Max
    I experimented a lot last few days with TGSL...Bad news is
    that i was wrong about replacing LM308 with TL081!
    TL081 is working but not that good as LM308?
    First time i tried that, was in hurry so i havent noticed
    differences. Now, when serious tests performed i am sure
    that LM308 is hard to replace.....or...maybe there is good
    way to replace it but TL081 is not best choice.
    Earlier it was piece of cake to null coill and gain very good
    results when LM308 was on pcb and device was used to null coil.
    Now it is almost impossible to gain good results and null coil
    when TL081 is put on pcb instead LM308??? I gain less distances on
    nickel coin and sound is "broken" when reach detection limit..
    I tried to achieve good results for over the 2 hours without
    success...!? Everything else remained same except those 2 TL081...
    I omitted those picofarads on 8. pin of LM308, of course,TL081
    not need those...
    So...feel like on begining again!?
    Havent try to change values of surrounding caps and resistors...
    Must be other way to achieve good results without LM308?
    With a lot of help from my friends i prepared 4 types of pcbs for
    TGSL....even one smd!
    Other people draw those pcb's so i am not allowed to post those.
    If original designers want to post their draws than let them do that.
    I am not post neither one cose simply dont have right to do that...
    There is 12x6cm TGSL onesided from my dear Dutch friend, 6x6 from one
    Russian brother and small smd from another good friend of mine...
    Also very nice coil housings in prepare...Soon to come and post photos
    here...
    On posted photo there are wounding bodies for two coil sizes;
    one is for DD 190mm x 107mm and other 255mmx155mm...
    I done some experiments using 0.20mm wire (0.22mm with varnish)..
    Body 190mmx107mm;
    130 turns=6.4mH =22ohms
    125 turns=6.0mH =21ohms
    123 turns=5.8mH =20.6ohms constrained=6.21mH
    121 turns=5.72mH =20ohms
    120 turns=5.57mH =20.1ohms gives frequency 14.9kHz
    117 turns=5.38mH =19.6ohms constrained=5.73mH
    Body 255mmx155mm;
    95 turns=5.07mH=20.1ohms gives frequency 16.18kHz
    Wire gauge affect inductance and frequency of course, so it is
    obvious that i should use thicker wire to gain proper number of turns,
    inductance and needed frequency. Wire should be 0.25mm to 0.28mm...
    Since 16.18kHz is a way to high (we need 14kHz) i should wound more
    turns, but it would raise resistance of coil to some 28-30 ohms...
    Not good, so if i use thicker wire, all will come on right place.
    Resistance will stay between 19-23ohms, inductance will be closer to
    6-6.5mH and frequency will lower a bit, just arround 14kHz....
    Problem is i left out of wire!? #$^@%^&^!!! I have to wait few days
    to find proper one...
    Only one problem left to be solved; LM308...It is not impossible to find it,
    i can...But i am curious to find proper replacement...That's me!
    Regards!
    you can try with LF351 instead of LM308... not the same but maybe you could find or have already. Other things, of course there are, but are difficault to find and you have to order.
    I found it works better than TL081... somehow; they are normally considered equals but they aren't I think ! Now also obsolete parts !
    I've found some suppliers of old LM308 on ebay... dip and metal case too (expensive one)... cause it's still in use in e.g. guitars preamps. etc but problem is that one have to make an international order for them...
    Kind regards,
    Max
  • Max
    here are just 2 pictures/part of it... low res
    it's BandidoII-clone using Gary's 1st PCB design.
    Other parts or higher res or OO coil I'll never show here.
    So think what you want!
    Kind regards,
    Max
  • Max
    I'm not interested in the schematics, but I was interested to actually see a photo of your TGS. Anyway, you said earlier that your friends were so impressed that they all wanted one. So it thought it must be worth a look.
    Also, how about some pics of the coils you have made, particularly the 12cm OO?
    My friends were impressed by BandidoII-clone not TGS.
    Already answered to you.
  • Max
    yes TGS exist... I've already posted here the PCB assembly, but I repost it again for skeptics
    About great performances they are related to BandidoII not TGS. TGS is still prototype no good case , no good tuning, lot of work to do...no real tuning on it , just few tests.
    And about 12cm OO coil it exist too... but I've no need of posting here anything of my work.
    Why if e.g. Esteban don't want to post his schematic here , I have to post here pictures of my coils ?
    To give him some funny argumentation on my coil ?
    My coils are nothing special, but they work. That's all.
    I've posted in the past cause someone asked me of posting round 8'' before sealing... if remember well I've done. Find it.
    DD22 was already sealed at that time and I haven't pictures of the inside woundings.
    BTW I have also some mods on bandidoII circuitry. Why I have to show you ?
    Now that this is your stupid game I say that:
    use your hands and build yourself both BandidoII and coil, and see with your eyes. You have all data you need here and in other threads.
    Many folks here have made what I've too, some first of me (PCB, coils) some after me. All with good results.
    These are not things from my imagination, but FACTS.
    Kind regards,
    Max
  • J_Player
    Hi Ivconic,
    Bese wishes,
    J_P
  • porkluvr
    Have you tried schottkys?
    Ivconic - I'm sorry to hear about your experience with TL081.
    Here's something that I have wondered about: I remember reading where you said you like to use the transistors/diodes version of the negative voltage converter - instead of using ICL7660. So, have you tried using schottky diodes (1N5817 is what I have in mind) in place of the 1N4148 diodes?
    The TL081 uses about 5X more current than the LM308. Using something like 1N5817 should give you almost one more (negative) volt to work with. Maybe worth a try?? It might help the TL081 work better. Of course the problem couldn't be so simple, but still it's an idea... .
    By the way, LT1008 (Linear Technology) is a direct replacement for LM308, if that helps. It may be be just as hard for you to come by as the LM308, so that wouldn't be much help - I hope that's not the case. Just two weeks ago, I got LTC to send me two free samples - but I haven't built a PCB yet. I also got LTC to send me one sample of LT1012; it's a possible "dual 308", but I don't have a facility in which to make tests, at this time. (Maybe I should feel guilty about getting freebies, but, naaaa. I don't.)
    Because LT1012 is a dual opamp, it doesn't have the "add a capacitor on pin-8" capability, (the 100pF capacitor on LM308-8 adds power supply noise rejection, by the way) but LT1012 might be OK dual, if I can ever get busy.
    Thanks for all your test info!
  • ivconic
    ooops!
    Ts...
  • ivconic
    More pain for me....
    not need those...
    here...
    Body 190mmx107mm;
    Body 255mmx155mm;
    Regards!
  • J_Player
    Does it really exist?
  • Qiaozhi
    Qiaozhi wrote:
    Hi Max,
    Did you not see my previous post?
    Esteban respond:
    No, Max don't!!!
    Did you see the red tantalium capacitor? WHAT A DISCOVERY!!!
    Like a red rag to a bull!
    Nice to see you here in the Tech Forum.
  • Qiaozhi
    I saw it. My TGS-clone is still a prototype have just tryed a few in test garden.
    I have too shame of my last creation that's why I don't post pictures of it...
    I've used unconventional case for BandidoII... something you'll never imagine cause the board (1st Gary's design) is really large.
    But I think using standard parts to pack TGS-clone... at now is in a rough state, I have few time to pack it well.
    I mean... I can post pictures... but, cause of the shame, with same resolution of Esteban's schematics !
    Anyway... it works... and BandidoII too... that's what important at the end.
    Kind regards,
    Max
  • Esteban
    Qiaozhi wrote:
    Hi Max,
    Esteban respond:
    No, Max don't!!!
  • Esteban
    Oh!!! What important!!! The truth, the truth, you only teorize, no TB, no TGS, and others ask and ask the teacher, and in reality you have not finish nothing!
    I want to see by your hands minimal resolution of schematics of your creation, OK for me!
    Also, you put my name here in a thread I'm nothing to see, so I'll persecute you, chemist specialist in solvents and poisons! Frustrate chemist? Your leonine solution for a simple problem!!!
