LM308 offset
Here is something I'm looking into that could greatly affect the sensitivity and depth of our TGSLs.
The quiescent output voltage of the LM308 (pin 6) is supposed to be 0 volts.
If it is not, then it will change the detection to varying degrees.
The threshold range of the U106 comparators is about 3.6 mV to 36 mV (controlled by sensitivity pot R36). If the LM308 quiescent output voltage is not zero, it will directly affect the the detection.
It is also important the both LM308 outputs have the same quiescent output voltage (if not zero), otherwise the GB and DISC channels will detect at different thresholds.
I just measured mine by removing the RX coil.
My disc LM308 output voltage is about 7 mV, and my GB LM308 output voltage is about -2mV. (I see some high freq noise there, but not sure if significant or just something my scope sees.)
So my case is not ideal, but no too bad, but if sensitivity threshold is at 3.6 mV, you can see there is a big relative difference. A negative offset would definitely reduce your detector sensitivity. In my case, I don't know if the amount I have is a problem or not. It could mean my LM308 precision ICs are not so precision as they should be. I got them for about 50 cents each. Or maybe a voltage gradiant along the ground buss is responsible, although it seems to check out fairly well. Could it be some high freq noise that get's rectified at the inverting inputs creates a bias??? Anyway, an area to check out.
QUESTION FOR OTHERS
I am interested if others could try disconnecting their RX coil and measure DC voltage at LM308 pin 6 for both LM308s (or whatever IC you have there).
-SB
QUESTION FOR OTHERS
-SB
