Originally posted by habitbraker
I found reason why output voltege was lowering with input increasing - my sig gen fault. Its dutty cycle was changing when level was changed. Well it is DIY anyway
Sine output is perfect at least.
I tried a small chokes in the output - didnt see improvements. Small oscillations appiered instead of sharp edges.Or Maby its better ?
I coded a fast pic code to generate 15.75Khz square and put it on the input. Output still 50Vp2p.
It connected other coil to the scope (10n parallel) and tried nulling and it looked very good. I could manage almoast zero null voltage. It was just fast and dirty test - didnt even remember actual numbers
One interesting thing. In ltspice this diode (see attachment) added 7V p2p (almoast 60Vp2p), but in real circuit it didnt make any difference. I dond know why. Even not shure what this diode does in sim?
I have one blank eduardo PCB. Maby it is worth trying solder one but instead of colpitts use this oscillator? But Im too lazy to solder right now
. Its too early i think..
You still need to make an oscillator, but maybe a simple relaxation oscillator or 555 chip. It would take some doing, but I'd definitely like to see what happens. If you end up with a higher TX voltage, you'd probably need to reduce the gain on the LF353 pre-amp to compensate. I hope you can get around to it.
-SB
(I must get thicker wire to test this)
... right!
