Jeohunter - Visual Ground Scanner
  • Hi geo-i!
    If the Accupack only lasts 3h there is something wrong! Perhaps these Ultrafires are cheap China cells with wrong mA declaration (I have never seen so many lies and wrong values as with accu-cells, most of them are much worse than the mA etc. describtion suggests). Or only a few cells are bad (you can test this if the pack is already half-used or weak). Or the charger has a problem.
    Your cells usually must work for 9h because those are 2x 3000mA and the Jeohunter works 6hs with the 4000mA original accu-packs.
    However, for the beginning your accu-pack is a good success and 3h may be OK until you get better cells or a better charger.
    Why detectors show us gold if it's a different kind of metal??
    That's a well know and often asked question and it applies to any metal detector!
    In short because gold has almost the same electromagnetical and conductive attributes than many alloys or other kind of metal. Tin-foil or copper as example and even special shaped stainless-steel.
    It also has to do with the size, because a thick piece of metal conducts better than a thin piece. And even mineralized soil can have an influence.
    Because of the bunker:
    Is the 20feet x 7feet cavity signal really a geometrical square or other shape? And do you get it still at 80% senstivity "loud and clear"? You have to be really shure of this because outherwise you may face the same beginner problems like I told to syed ayub basha.
    Is the ground where you have detected the cavity made out of concrete? Perhaps you have already found the ceiling (roof) of the bunker? Maybe you will find the entrance inside of the abandoned house or somewhere nearby?
    If you found the bunkers concrete it would be very massive.
    And if this was a military bunker be careful about old ammunition, mines and other dangerous stuff around!
    However, you're on the right track for treasure hunting and congratulation to your already first huge find! Thanks for the picture - seem you found it in very high mineralized ground. It's like with in some Role Playing Games - first you have to built up alot experience-points and then you get to the big treasure-chest. But with the Jeohunter you are really starting from the best position! Good luck, geo-i, and I hope you will find a way for a second and better accu-pack!
    • sir funfinder, you just confused i am talking about another site, not plastic barrels. it is another, now read my question. in the barrels site corn crop is present so i postpone the project for some months. in the same place one old ruined village is there we go there and find one large signal @ 100% sensitivity. i turn the my sensitivity to 80 or 70% signal not found. then i thought @100% sensitivity detecting depth increase. at lower sensitivity detecting depth is reduce. is it right or wrong?
      • Hi syed ayub basha,
        without detailed info everyone would have thought you're after the barrels. "I work one place" tells nothing about any new situation.
        Guess you know that 100% sens. gives more depth but you can't handle this yet, especially not at some ruins where stones and ground is mixed up alot and the ground balance could've been critical.
        Bury a piece of metal below over 1feet, close the hole and then try to detect it the same way and speed as you search usually, first at 70% and after this at 100% sens. - and you will see the huge difference. The same applies to cavity.
        Good luck.
        • video joehunters
          hello my friend fun finder do you have a
          video finding tunnel or bunker with the
          joehunters detector can you send to me
          i hope so thanks.
          • Hi geo-i,
            I hope you are fine and now cured from flue or fever.
            You know my video of the iron-bunker-tunnel-door already
            detected from around 2.7 meters and I guess you wanna
            watch a cavity-detection-video.
            At the moment we have 1m of snow here so I can't
            shoot such a clip.
            geo-i, first you have to find out if this is really the ceiling of
            the bunker or it is just an area with concrete on the ground.
            If it is the bunker you should get a different signal near
            the below strong walls of the bunker at the borders where
            the signal starts.
            But if the concrete ceiling is very thick you might get no
            different signal.
            In that case the only way to find out if this is really the
            bunker is to bury a deep hole where the concrete starts
            so you can find out if this is the outside concrete-wall
            of the bunker or if it is just a thin layer of this stuff
            (but I think this is not a thin concrete, otherwise
            you wouldn't get this strong cavity detection).
            Maybe you should find something to blow the concrete.
            • Wrong Question
              hello my friend sorry for the wrong Question i ask
              it right what you guess i wanna watch cavity detection
              video bro sorry again bro never mind may be the snow
              give me a challenge to see the cavity over there bro
              i hope can found the ceilling and not too thick thank for
              whish my fever now it get better
              geo-i
              • reset button modification
                hello my friend fun finder can you help me i try to build
                reset button modification as you show but all recipes is
                enough i thing why the functions is not right are you
                sure the connection circuit that you give is correct ?
                i hope you can help see picture
                geo-i
                • tried double check
                  hello friend perhaps you are mistaken
                  please tried double check again bro
                  when i try to install the joehunters
                  the screen ground balance it sound
                  repetitive and the ground balance
                  cannot be adjust switched cannot
                  move are you test the device bro
                  what happen and the problemo .thanks bro
                  geo-i
                  • Hi geo-i,
                    my big respect! You are the first who tries the reset button mod!
                    You will see this will work perfect!
                    But first I will help you to find the error.
                    We will find the problem very fast because this is just a simple multiple on-off switch configuration!
                    If you press a touchpad button, a contact will be closed:
                    from the (both connected) signal-line contacts to the corresponding button (see below)
                    What I can see is: you have soldered the wires in the right way but you may have forgotten to attach the flat ribbon cables after the work or you have plugged them in from the wrong side!
                    Attach the flat ribbon cables in the exactly same way as they have been before.
                    Both should describe a bow form from outside view.
                    And make shure there is no permanent contact between the new cables,
                    the both connectors/plugs or the switch / little pressable button you want to use.
                    Please show me a picture of the attached flat ribbon cables and of the touch-pad panel so I know this is the same.
                    • Jeohunter @ Full Highspeed !!!
                      Buy the domain name Qooy.com and launch your business with a premium domain and a high quality logo.
                      • Can you post a link that works in a sensible manner....Thanks in advance.
                        • No!
                          Because this is the most sensible manner!
                          What problems do have now again?
                            No!
                            Trying to find it.
                            • touch pad& flat ribbon
                              hello my friend fun finder here is the picture of the attached
                              flat ribbon &touch pad panel bro .but i have a another problemo
                              with the window screen goes like crazy bro please help SOS
                              i hope you can finish this problem.thanks
                              geo-i
                                No!
                                I eventually managed to download the file using "deposit files", after following a somewhat convoluted process, and having to enter the special code twice. After watching the video, I now feel a bit dizzy and a little nauseous.
                                It would have been better if you had compressed the file in rar format, then split it into 1MB chunks and posted them here.
