@ Orbit
The Jeohunter uses a powerful, high sensitivity and electro-smog-immune non-motion induction-balance circuit that also works great with the huge 1m coil.
@ Hi tabarki
You are lucky, I saw your new reply today and I have time at the moment so I can answer your questions very fast here.
You're welcome for your thankful greetings!
The exact gold notch filtering is complicated or in other words the range of gold is variying alot.
The Jeohunters gold detection wants to be on the safe side so you don't miss any metal-object that still could be within the detection-area of gold.
There are really huge differences - per instance very small gold-chains made of cheap alloy have the same metal-recognition value as iron.
And large steel objects, especially if those are sphere-shaped, can even get the detection value of silver.
It is not possible to adjust a metal-detector to 100% gold. Even if the find is made out of pure gold - if the size is different than the used object for adjustment or if depth or ground-mineralization changes it would be out of range and no longer showing up as gold.
If you own some objects made out of gold like rings, pendants, coins etc. I suggest you put the Jeohunter and the coil at a nonmetalic place and make some in-air test with them. Also use silver objects so you can compare how different the results are.
The most important thing is that you will get experience very fast for what are real detection signals (first use lower sensitivity and doublecheck the signals) and that you will learn to search large sites within the shortest possible time. The Jeohunter has 3 different coils so you even can use the small one for little stuff but this detector is built for maximum depth and for scanning huge areas in no time. If you have learned this and if ya know already an area where treasures might be located you can search through areas of 100 x 100 meters in 1-3 hours, depending how many trash objects there are scattered, too.
Keep in mind for later that you will get the most depth if you are hunting in all-metal mode.
But for now at the beginning you will get the best success-experiences if you are hunting in discrimination mode (iron-off) at ca. 70% sensitivity and if you are moving the coil in a short time over a largest as possible area, perhaps at 5-10cm above the ground. And its better you do this already at a promising treasure site because that way you can check out directly if there are finds that you wanna find.
Sometimes true treasurehunting also needs to remove alot trash and junk first until you are able to detect the good stuff below.
Infact at some places the good stuff is covered by 90% trashy objects. For training a site without such stuff is better because it will be more motivating.
It is also important that you learn to change and search with both arms because this will highly raise your durance and physical energy level.
You may start with the more lightweight small coil but the medium coil for shure needs some time to get used to the weight and enough musclepower.
However this is no big problem because if you have the needed experience the most of the time it will take just 1-3 minutes of sweeping the coil until you will have discovered the next find and can "rest" while digging the stuff out of the ground.
Also please don't wear shoes that contains steelcaps because the Jeohunter is sensitive to detect them even if those are 40cm horizontally away from the coil and also a good idea is to get a shovel where only the digging part is made out of metal (and the rest wood or plastic).
It is also important that you will equip yourself with a good pinpointer if you are hunting with the Jeohunter and the medium coil.
That way you can identify much faster the exact location or even the depth of the find. This really can save you alot time.
Well then, please keep me informed how you are progressing, what you also need to know and good luck with your first - hopefully treasure! - finds.
And again my congratulations to you that you bought this detector because only a very few persons find their way to this really powerful MD!
Too many treasurhunters are "captured" by little 25cm coil detectors that are lightweight and simple to use but totally fail on high mineralized ground
or if electro-smog sources are nearby and of course they will be never able to detect the real deep stuff or cavity and meteorites.
I'm just hoping that you are hunting at a real good treasure-location so the Jeohunter can show it's full performance there. Good Luck!
@ Hi tabarki
