Im struggling to recall if the machine Ive used on the beach was my old IGSL or IDX. However, I didnt think either would fly on wet sand - the one I tried didnt like the boundary between wet and dry either - it also did not like patches of rock under the sand.
It did well on damp or dry sand. Cant recall if pools were ok. I guess the surf is a no go - realm of the Pi or dual freq like the fisher.
I live in central england so I dont get to the coast. I must get to the beach on a solid low tide. Ive a reasonable Surf and an IDX at 12kHz I shall take.
I havent ran my car since oct as redundancy in june last messes up finances. I have been refurbing my car and hope to get it going and thru mot in next couple of weeks. Then Ill make a day trip to coast and have a big session.. See how the idx ans surf Pi do..
S
IDX-PRO+VDI
Yes very wet and some from under a few inches of water in rock pools.Originally posted by golfnut View PostGood little haul.
Was this on fairly wet salt sand - if so you did well - these cant really run on wet sand. Drier sand and dry sand is fine for these, as is clean soil, and short dry grass.
S
Still can't work the area where the very dry meets the damp (jumps all over the place) but the the fully wet is very doable.
Could not work any very small pools as the edge of the water to the sand gave a signal.
Floating the coil on top of the water and moving the coil very slowly gave very good results. The old 10p came from under 3 or 4 inches of water.
Could not ground balance over the wet sand out side of my range. But by moving the coil very slowly slight up and down movement are noticeable in all metal mode but easy to deal with as soon as you over a real target it really jumps out I just had to slow the sweep speed right down.
Once over a target switched to disc and only moving the coil a few inches from side to side listen for a clean tone.
Normal sweep speed in disc mode pops and squeaks all over the place.
The old padlock was the only iron I dug and this was a slightly iffy signal
one of the 9mm FMJ gave a slightly iffy signal that I probably would not have dug but noticed it was sitting on the ground
Majority of the finds were from a tight area did walk either side and the finds were a lot more sparse. Ground was slightly different think it had been dumped from somewhere else in the last storms
Strange range of dates musket ball to WW2 ignoring the old decimal coin that was from about 50 yards away
Good little haul.
S
Hi, awesome colection of military items! thank you for your feeling tone detector seems to work well.congratulation.
Originally posted by Koala View PostHad a good couple of hours out with homemade IDX (original silverdog board no modifications) with a stock 8" concentric.
Not had much success in the past over wet salt beaches. Started to use a different pair of headphones and the good and bad tones are much more pronounced. Ground balance over the wet ground was just pass the range on my potentiometer (will have to adjust this) and searching in all metal mode then testing in disc mode if the target is iron. Keeping the coil the same height from the ground and searching in all metal mode the lack of ground balance did not make that much difference. Most of the finds were from an area about 20 foot by 15 foot and not much junk dug
[ATTACH]28467[/ATTACH]
Not all USB2 are the same. There are some dreadful cheap ones on eBay. Unfortunately you can't tell from a picture or from feed back. I have used a USB2 cable with no problems go with a known brand there not much dearer.
Ok Don , for the wet grass I'll try again DD coil between the two shields. we'll see what happens. for the moment I'm trying to make a elliptical coil for IDX detector I think it is much more complicated to balance that double D coils
Originally posted by dfbowers View PostThat wet grass problem with the TGSL was a real pain in the butt. It didn't seem to matter what coil I made or how may circuits I put together. I like to hunt at night alot and wet grass is a normal thing. Keeping the shield grounding separate from the Tx and Rx coil definitely solved my headaches.
The White's grounding scheme is the same as what I came up with for the TGSL project, so you should not run into that.
Also, I was wondering how others made out with USB cabling for the White's coils. I have only tried Belden 8723 so far with the IDX project.
On a different note.. more snow here in the Eastern U.S. last night. 4 times in one week Uhh.. Snow covered with ice, covered with snow, covered with snow. Walking in the yard is a B!7(h!!!.
Don..
That wet grass problem with the TGSL was a real pain in the butt. It didn't seem to matter what coil I made or how may circuits I put together. I like to hunt at night alot and wet grass is a normal thing. Keeping the shield grounding separate from the Tx and Rx coil definitely solved my headaches.Originally posted by golfnut View PostI would go with the usb2 Barry. Ive never used it so cant comment.
Nel use 2 coax's as do ML on some, like Explorer2.
Belden 2x twisted pair screened is one option.
i dont think any has more sens over any other, the loss thru all of these is fairly low.
If you will be out detecting on wet lush long lawn/meadow grass there was a screen connection option in Dons TGSL write up for a DD.
S
Don..Attached Files
THANKS,,STEVE ,, GOOD advice as Usual..
KEEP DRY over there in the UK ,[Not good M/D-ING weather]
CHEERS ALL ,,,,,,,,,,BARRY..
S
OK,, Yes 200ks from major Shopping such as Electronic -stores Large super-markets etc etc..Originally posted by Koala View Post200K from shops
Here in the UK it's under 1000K form one end to the other diagonally
We do have general food stores within 25ks ,chemist,doctor etc but no specialist stores ..
Since having computer I shop online for electronic bits ,that is I am not driving to Adelaide ,where we have 2x really good Electronic shops..
The one good thing about living here is only 130 residents in our small town [A farming district] BOOBOROWIE..
Well I am to test another DD coil & my H/made shell & will not pot untill nulled for certain !!!! STEVES advice ..
I was to decide on what cable to use [Asked in last post] Wether 2x coax ,or,4x core individual screened cable has advantages over the USB2 such as better detection [senitivity etc]???
I see most are happy with the USB 2!!!! But I have the above cable also..
CHEERS,,,,,,,,,, BARRY..
200K from shops
HI ,, THANKS for that info S/user ,,thats interesting the Acrilic paint as a base for the graphite I thought that Acrilic paint was water Based ?????..
Yes I think I would give the expanding foam a Miss after the messages recieved here..
YES PET SHOPS !! unfortunately I live 200ks from shops like that but I will check them out..
CHEERS From OZ,,,,,BARRY..
@ barry home made graphite paint applied to the inside of the shell, originally applied to paper tape stuck on the inside, now i use acrilic paint designed for plastics as my paint base.
i have tried expanding foam but it has problems, firstly there are different grades( lower density is a must), secondly it can force your coil apart,you need to either seal it really well and not put to much in , or not seal it but bolt it together with nylon bolts then trim of the access after it sets then seal it, thirdly some of this foam gets hot as it cures.
but finally some also has iron oxide powder mixed in it and is detectable (by vlf).
personally its not worth the hassle, better to cut sheets of the dried stuff and add it during construction, some of this has iron oxide in it too (the colour gives it away) so test it for detectability.
p.s. beach shops and pet shops sometimes sell frizbees.
