Originally posted by Schatztaucher
IDX-PRO+VDI
sorry, my picture is not correct!! i need more times to make it new!!Originally posted by Schatztaucher View Post[ATTACH]25731[/ATTACH]
pictures in post 1520Originally posted by medj View PostThank you Koala
Did you change anything else in the device or not
Possible scheme created by the device
Ademna some pictures
I will be thankful to you
Highly recommend silverdogs PCB good quality and 100% working. Could have made my own PCB but it's really not worth the effort. Just follow the values printed on the board to make an excellent metal detector. Everything work perfect.
Thank you Koala
I want to ask you
What are the spare change it in a
Or not change anything
Do you change the resistors next r7 r8 r25 r26 change the number of laps tx rx
My original coil "Classic I SL" measures 3.88 ohms from the end of the cable that includes the resistance of the cable. There may be some variations in coils.Originally posted by Aiko View Post6.6 ohms is too much for the IDX-PRO TX coil. You will get very low voltage of the TX. The correct value is 1.6 ohms.
"i have just finished my silverdog idx and it appares that is not working properly ."
Hard to say,, try all of the usual stuff Do you have plus and minus 4 volts..
Do u have a scope or access to one can u measure thTx coil volts should be about 15v ac
Pos a good pic of your board
S
6.6 ohms is too much for the IDX-PRO TX coil. You will get very low voltage of the TX. The correct value is 1.6 ohms.Originally posted by gtdavid View Postthe coil ohms are tx 6.6 and rx 39
i cannot tell the exact modal of the coil as i got it from a market its 11 inch with wights sticker on it
threshold has a noticeable change in pp mode.
97386 is the zip code so not going to help much. On the left lug there should be a number stamped normal very faint. Can get worn off. Maybe if you post a picture someone on here could identify it. Buzzing in PP altered with threshold pot and quite in Disc mode is correct. Just test a working MD and get nearly 4 volts AC across the TX connectors
there is 97386 on the sticker.
no i don't have a scope unfortunately.
and i guess you could say buzzing yea.
thanks
Is there not a number stamped on the left lug of the coilOriginally posted by gtdavid View Postthe coil ohms are tx 6.6 and rx 39
Do you have a scope to test the TX and RX are working correctly
Just re read your original post you say beeping in PP do you mean buzzing.
