IDX-PRO+VDI
  • onuba
    It works perfectly and to the first jajajaj ,2 tones does not work tendre envestigar Or pondre vdi better
Name:	26-3-2013 21.3.28 1.jpg
    Thank you very much eduardo helping and to give me advices
  • Ropcsika
    Originally posted by kabier View Post
    hi Ropcsika thank you and so the feedback loop inside the rx winding
    thanks
    Yes, inside the rx.
    See:
    A képet a Képfeltöltés.hu tárolja. http://www.kepfeltoltes.hu
  • kabier
    thanks
  • Ropcsika
    hi Dfbowers can you please post the parameters for the 10 inch concentric
    thanks
    Hi Kabier.
    This is my concentric coil parameters:
    - tx winding diameter 240mm ! tx 0.72mm, -29 winding 1,6 ohm, 0,523 mH
    - rx winding diameter 120mm! rx 0.2mm,- 370 winding 80,2 ohm, 35,2 mH
    Data for the concentric
    - feedback loop , diameter 113mm ,10-12 winding 0,6 ohm, 0,019 mH
    wire 0.72mm .
  • kabier
    thanks
  • onuba
    I can replace the BC547 for c549b n idx pro
  • ashefr10
    ideal for this porjet would make one motherboard combining the multi-tone and vdi
  • onuba
    I can put two tones pbc transistor BC549
  • ashefr10
    hello, for stability if you toujour the same problem, read the post 1252 edouardo R25 therefore advised to remove your resistance adjusted and put a 4k7 resistor between terminals 6 and 7 of the LM393 (IC4)
    Originally posted by reiv View Post
    Edurado could you just replay for my question in #1249
    After this Yours update:
    C23 - 3n9 -> 3n3
    R24 - 1M -> 2M2
    R25 - depends of U4 (my value about 800Ohm)
    D2, D3 - out
    VR3 - out, only R43 1k8 -> 2k2
    I have worst masking, and my idx is a little unstable- is it normal or I have some sort of problem?
  • reiv
    Read post #1248 there is a answer for your question.
  • ashefr10
    I wanted to know why the two 1N4148 diodes, the variable resistor VR3 had disappeared and it was replaced by a thread, and if it was wise to put a 2M2 instead of 1M nothing more
  • ashefr10
    I quite agree with you, but not that lazy, there are also novices, and even reading the 50 pages it is always good to ask rather than do anything.
  • reiv
    I didn`t ask You! ,sorry. He has fully right to lost his patience, when most of people is soe lazy don`t want to read 50pages of this thread -better put another post like: "what is the value of threshold, or what about D3, VR3" 101time..
  • ashefr10
    Eduardo does not want to help it regain tired of the same things 100 times! Sorry.
  • reiv
    C23 - 3n9 -> 3n3
    R24 - 1M -> 2M2
    D2, D3 - out
