IDX-PRO+VDI
Why you join two of the C16 feet at the time of the usage of the pinpoint? He functions properly without this at me.
PP
Some people mention that although the PP works on IDX even with a DD - they have to move their machine a bit to get a PP fix.
This is because the PP CH is not DC coupled right through - it has a 1uF cap in seris with it.
So in order to get a signal thru the cap you have to generate one my giving the machine a rock about.
To make a true non motion PP which reponds to phase rather than frequency you need to short C16 out during PP mode.
I use a DPDT switch - one to turn into PP mode rather than the push button in the kit and the other switch to wire out the cap.
Another option is to put massive cap in like 100uF that can pass small phase changes more easily.
Nice
S
swap rx wires over and retryOriginally posted by Schatztaucher View Postthanks ropcsika....my values are all ok. to pin 3 of u1 I measure 0.2 mv. is an original coil.
r25 set to 700 ohm ..... and no change!? but whatever. I'm testing on. what I have noticed that my pp does not work properly. the all-metal.mode I must move the euro too.
can someone tell me how I do the pp? from the manual, I'm not really smart.
Originally posted by Schatztaucher View Postthanks ropcsika, also have a board of silverdog. and the same components installed .....
and an original coil....:-( then I have to go expirimentieren further to get to better results.
Nulling the search coil is important. I measured the value between the u1 ic's 3rd pin and the gnd. Value: ac 0,0-0,4 mV. Good result.
Concentric coil data:Originally posted by Schatztaucher View Postvery nice too:-) and very good results. I do not understand why my idx gives not so good results. a Euro only detect up to about 25cm in the air.
have the board soldered precisely and accurately ....
what is your secret?
ropcsika, can you tell me, which components you have used? ic's specifically, R24-26 and what poti for P5?
- tx winding diameter 240mm ! tx 0.72mm, -29 winding 1,6 ohm, 0,523 mH
- rx winding diameter 120mm! rx 0.2mm,- 370 winding 80,2 ohm, 35,2 mH
Data for the concentric
- feedback loop , diameter 113mm ,10-12 winding 0,6 ohm, 0,019 mH
wire 0.72mm .
ic's: u1 5534Originally posted by Schatztaucher View Postvery nice too:-) and very good results. I do not understand why my idx gives not so good results. a Euro only detect up to about 25cm in the air.
u2 cd4066
u3 lf347
u4 lm393
u5 lm358
u6 lm358
u7 lm393
u8 lm393
r24 1M
r25 1k multi turn potentiometer adjust about 700 ohm
r26 100k
p5 100k linear
pcb from Silverdog (home made)
Hi, if anyone tried to put VDI`s .hex file in PIC 16F88 with succes by popular JDM or JDM2 programmer? Or maybe any simple to built programmer or connections to do that. I saw epic programmer in this thread but for one .hex write is to complicate to built 4 me of course
Rav
