IDX-PRO+VDI
  • I have another scheme.
    • To your scheme Click image for larger version
      • Friends, can you help me? I assembled and tested my IDX Pro metal detector, then I built the 2-tone sound circuit and connected it correctly to the connection points, but it keeps beeping. Could someone please help me with this?
        • Merhaba arkadaşlar Aleks85 usta paylaştığın devrenin bobini soracaktım dd mi concentrik mi balıktan gelen gnd ucunu anlamadım ekranlama yapılıp mı gndye bağlanıyor son olarak pcbsi ve ölçüleri varmı teşekkür ederim
          • eduardo1979 Hi Eduardo, could you help me with my two-tone circuit? As you suggested, I removed the R55 resistor and made the circuit connections correctly, but when I connect the BC517, it constantly beeps, as if it's detecting something, but it keeps making a sound and the BC517 burns out. What could be causing this problem?
            • Originally posted by Alikkc View Post
              Please read the forum rules -> Basic Rules of the Forums​
              • Hello friends, I wanted to ask about the coil in the circuit you shared, Aleks85. Is it DD or concentric? I didn't understand the GND wire coming from the coil; is it shielded before being connected to GND? Finally, thank you for the PCB and measurements.
                • This sensor IDX_Concentric_coil (1).pdf
                  • The shield is a shield, the signal wires should not be connected to the shield.
                    • 最新pcb
                      • 修改版PCb
                        • Originally posted by HaaKaaN View Post
                          • Hello everyone, I want to build an IDX Pro metal detector, but I am confused about the PCB versions.
                            Which is the final stable PCB layout (single layer) that is suitable for printing and etching?
                            I am looking for a black & white printable version (1:1 scale, mirror if needed).
                            Also, what are the exact PCB dimensions?
                            Thank you in advance!
                            • Please I need the Gerber file of IDX pro
                              • Hello, I would like to request a Gerber file for IDX Pro. I attempted to generate it using Sprint Layout, but PCBWay reports an error with the file.
