IDX-PRO+VDI
  • Originally posted by ashefr10 View Post
    HELLO, now that I finished my tgsl with 2 tones, I launched into the idx pro with 2 tones to see the difference. I wonder if I can use my coil tgsl for testing? or if we must rebuild a coil are what I can do a DD and what would be the values ​​for a number of turns DC 20 cm?
    what is the optimal coil, concentric or DD?
    You have to make another coil for IDX.
    Of TGSL does not apply to this unit.
    The inductances are very different.
    My coil DD27cm:
    RX = 260 turns, 0.20 wire more parallel capacitor 47nF
    TX = 34 turns, 0.60 wire more 1uF capacitor in parallel.
    They are the best results achieved so far.
      My coil DD27cm:
      TX = 34vueltas, 0.60 wire more 1uF capacitor in parallel.
      34 vueltas for TX ??
      34 turns ?
      • 34 Turns.
        • I can no longer set a geb effect on my tgsl since I put the card 2 tones . why ?
          • I really feel the same. So you do not pass so you have to build the IGSL. The TGSL has separate channels for the balance of ground. Ferrous and non ferrous.
              I actually hope for a better functioning mode of 2 tones of idx
                At the moment very difficult. The solution would be the Arduino.
                  My coil DD27cm:
                  hi eduardo ,
                  rx .tx henry ? and ohm ?
                  • Originally posted by tekin_efe View Post
                    hi eduardo ,
                    TX=1,7 ohms=0,59mH
                    RX=90,4 ohms=34mH
                      TX=1,7 ohms=0,59mH
                      RX=90,4 ohms=34mH
                      thanks eduardo. Have six videos shot in the field of soil I'm very curious about the power under the ground shot.
                      • 1€ coin 35cm.
                          1€ coin 35cm.
                          Do you have a chance to be a great show video capture
                          • No.
                              No.
                              okey eduvardo thanks .
                              • Discrimination of idx is more efficient than the TGSL?
