IDX-PRO+VDI
  • seadoggy
    Originally posted by gaby_sult View Post
    What is the recommended coil and which data coil diameter and induction for IDX?
    I using this shape.
Name:	sonda nacrti.png
    TX-0.580 mh wire 0.65(cap 1uf)
    RX-35.2 mh wire 0.20(cap 47 nf)
  • Koala
    Homemade data is on the first page of this thread and the DD shape is the same as in the TGSL101 PDF
    Factory coils the Whites 950 works well. Be careful with their concentric. The ones built for most of the older Classics will not ground balance properly or will be right at the end of its adjustment.
  • gaby_sult
  • gaby_sult
    DD 255x137 template to TGSL but characteristics TX - 0.7CuEm 35 turns - 0,587mH - C = 1uF and RX - 0,2CuEm 265spire - 35,6mH- C 0,033uF. As adjustment VR1 has some effect but not all remove ferrite
  • Koala
    Who can help me ? VR1 is minimal and does not remove all ferrite, why and what they can do?
    What coil are you using ??
  • gaby_sult
  • manu72
    Thanks Davor.
  • Davor
    You may use your PC audio input and a PC oscilloscope program to do that with no cost. You may expect the remaining signal about 1mV at very good balance, and that is what your PC sound card can process.
  • manu72
    Hi, i have finished my IDX pro, but I have no oscilloscope to annular coils, i'm thinking of buying one for PC, I wonder if this can be worth http://www.ebay.es/itm/Hantek-6022BE...4AAOSw0HVWAlw2
  • mohandes
    hi guru
    i have new question and it is:
    The received signal at the resonant frequency receiver and only the phase change.please explain
  • seadoggy
    Originally posted by CDI View Post
    Which cable did u used? Does your shield is separated by each other? Thx
    USB 2.0 cable,yea it is separated.
  • CDI
    Originally posted by seadoggy View Post
    yea its work very good i use LM324 instead LF347.
  • seadoggy
    Thank's Seadoggy, great job. Did u tested finished md with this board in real soil?
  • CDI
    Here is my IDX pro with pots inside board!!,very good and stable board!!
    Enjoy and best Regards
    [ATTACH]34660[/ATTACH]
  • seadoggy
