BARACUDA-Legend-1
  • Wilson
    Check possible short circuit in the welds.
  • mohandes
    tell me
    Hi all
    now i watting to your help , i put finall board and need to connect headphone, tresh pot, and switch and...i certain in past pitures,please tell me
ID:	336309Click image for larger version
  • mohandes
    i do that mr porkluvr and mr wilson
    i need finall help
    who can design in Paint or...for me ,my ? in the picture(simple and easy please)[i just to connect the switch and phone and..but dont know how do the wires,see picture and design simple for me ,please)
    each picture you think is simple and better for me.
ID:	336306Click image for larger version
ID:	336307Click image for larger version
  • Wilson
    Mohandes, the reason has Porkluvr the fets should be rotated 180 degrees, the resistors are 2M2 or 2.2 Mhoms (red, red, green) The IRF9640 is installed in the same position TIP127 and A14 is correct.
  • porkluvr
    Mohandes,
    I believe the BF256 are installed backwards. It looks like the PCB was created for 2N5484,5.
    2M2= 2.2MΩ
    (You penciled the IRF9640 pin assignments backwards.)
  • mohandes
    need to guide
    hi tonight i finish baracuda that design by Apberg,
    now mr wilson and Apgerg i ask my ? in the pics and need to help ,please answer.
    cheers
ID:	336301Click image for larger version
ID:	336302Click image for larger version
ID:	336303Click image for larger version
  • Wilson
    Ok Mohandes, good luck!
    Hugs.
  • mohandes
    [QUOTE=Wilson;172277]Mohandes you will have problems with this PCB, many points in a short circuit and other points too close, check very well compared to the original design.
    How to use the fet BF247A I believe it works, if not we have to leave the original for what we have at hand with characteristics as close as possible.
    Hugs.
    hi my friend
    yes i know because my paper not good and do that,i know these errors but i say thanks for your attention.
    ok i buy bf245 and 256 and 247a and i set on my board and check their works(each times one kind them)
    merci
  • Wilson
    Hugs.
  • mohandes
    this is my pcb
    i am going to make it,mr wilson please tell to all your detecting in the ground please
    and my engish is bad i think your means i use bf247c( but i said have bf247a, is it good)
    cheers and regards
  • Wilson
    Hello Mohandes, try fet BF247 preferably with the letter C at the end ok, do not forget to rotate 180 degrees.
    The transistor 2SC2026 is not a Darlington, search Google for characteristic similar to the original.
    MPSA13 Transistor Darlington NPN TO-92 30V 500mA MPSA13
  • mohandes
    Originally posted by Wilson View Post
    Hello Mohandes,
    Q3, Q5, Q7 = Fet BF245C
    Q6, Transistor Darlington = BC517
    Please note: all they must be rotated 180 degrees because the pinout is different.
    Hugs.
    hi
    i just can find bf256 or 245 (no 245c) or bf247a,can i use them?
    or do you know another equivalent?
    andcan i use c2026 instead of bc517?
    cheers
  • bernte_one
    hello wilson
    many thanks, i think you have unlocked the last secret of this unit
    i will install this mod too at my current board an will test it
    kind regards
  • Wilson
    Photo and link to barracuda with pimpointer function.
    Hugs.
Name:	Barracuda pimpointer.jpg
  • Wilson
    Hello Mohandes,
    Hugs.
