Hello Volcano, eliminated 270K resistor ic pinout different from LF357 NE5534, iliminado "offset" because I do not have the original ci.
Attention: The PCB has been modified to correct the use BF245C pinning.
hug.
BARACUDA-Legend-1
Barracuda problem
Hi
I have build Barracuda from silverdog and after i play with it a few seconds, the detector starts to make an intermitent beep beep beep every two or three seconds.
I rechecked components placement and values and this are correct too
Battery is fully charged and coil is the correct one. Any ideas of what could be wrong?
In advance many thanks
Nelson
Thank you to all who posted all the details of the equipment in this forum, and we can build.
Alexismex, I have a doubt about the value of the resistor that is connected to pin 7 of IC 7660 is 2M2 or 100K.
Thank you.
Nice work! Great machine to use at the beach. Just take a good shovel with you
Thank jap, following a photo.
Fet BF245C
TL082
LF357
IRF9640
Good results from a Wilson Barracuda
Whether slow motion or fast motion.
best time
j.
Hello, this is my Barracuda.
i have a question can i use the coil exelerator eq2 for minelab gpx 4500 on my bara?
thanks jap i read the original literature/reviews and i understood it as iron tone identification
and earlier on in the thread alexmex was it seemed to me screaming at us "its due to the tip27"(though noone in the thread was listerning to much off topic nonsense)
plus i'm not having that "the switch/trans is unknown" i'm positive the collective brain power of this forum can crack it if properly stimulated as for sinclair
at maikl i designed my barra to run 9v anyway(with the option of going to 10.2 by adding another aa cell
When the power is 9V then TIP127 not heated, and of course the coil L=450uH and R=1R5.
Hi sinclairuser
tone discrimination of metals as a alexismex view ----- When you use tip127 or irf 9660 a different in tone sound is heard ,to sound metal and another sound metal that another ,
is what he meant another.This requires training on the difference between each tone for each metal. ******Expect when you use tip127 a little heat will*******.
----Whenever I saw your name and avatar i Remember my days past when i use sinclair 128----
best time
j.
thanks know about farnell but sometimes you find new sources if you dont ask you dont get!Originally posted by Qiaozhi View PostHere are a couple of obvious places:
Farnell ->
RS Components ->
http://uk.rs-online.com/web/c/?sra=o...tip127&x=0&y=0
