BARACUDA-Legend-1
  • Hi, I'm new to the forum, a greeting to all, sorry for my English, I built the barracuda but I can not get sound, I have the following votajes (image) remplaze the q3 for bf245 and u4 for TL072, coil test with one of 20cm 23 turns of 0.5mm wire and zero sound.
    greetings thank all
    • Offset should be adjusted to give 0v on NE5534 pin 6
      Check pin orientation of BF245
      12v supply is recommended, 9v is not good
      • Hi, thanks for the reply, I wonder that in the original circuit q3 is not a MPF102 ?. apparently they are the same but there must be some difference. Another person to not get 102, 245 sets q5 q7 but puts 256 Q5. (102, 5485, 256, 245 are all VHF / UHF Amplifier (N-Channel). But there must be a difference, just notice that the arrow on the 5485 and 256
        They are in G and the 102 and 245 is in D.
        thanks
        • I used 2N5485 for all the JFets and it worked fine.
          • Thanks, then you use 102, only 4585?. 4585 can not get, I'll try 2n 2n-5458 2n5458 5458.
            thanks
            • Originally posted by matiass_mdp View Post
              thanks
              yes 3x 2N5485
              • be careful with the orientation of the 2N2222
                Depending where you buy PN2222A and 2N2222A are the same but P2N2222A is 180 degrees different
                by the way link looks like the image BF256 is wrong
                • Thanks for your answers, it may be that the coil is the problem ?, or more poorly constructed this at least would have to be sounds in the speaker anyway?
                  thanks greetings
                  • Coil not that important for getting a threshold tone.
                    Delay and Offset if too far out will cause no sound when target passed.
                    TIP127 should get warm but not hot.
                    • hello, again annoying, the variable resistors of 25k that value must fix aprximadamente. I do not use the 102 (pictured), I create some bridge?. thanks greetings
                      • question, R15 and R39 are: Trimmers can be Variable resistors (potentiometers) variable capacitors, inductors or trimmable. ?.
                        thancks
                          thancks
                          no only variable resistors!.
                          • my bara work ok?
                            • Originally posted by mohandes View Post
                              Moohammed, can you pls give not iranian links' sources just cause the majority geotechers are not able read in persian?
                              something from ENGzine range pls.
                              • Mohandes looks like your detector is working well.
