BARACUDA-Legend-1
  • i need help
    i can't adjust u2 (ne5534) pin 6
    here some info
    2n2222 base
    Click image for larger version  Name:	8.jpg Views:	0 Size:	70.7 KB ID:	440472
    irf9640 gate
    Click image for larger version  Name:	7.jpg Views:	0 Size:	69.3 KB ID:	440473
    cd40106 pin4
    Click image for larger version  Name:	1.jpg Views:	0 Size:	68.3 KB ID:	440474
    cd40106 pin6 (main simple delay)
    Click image for larger version  Name:	2.jpg Views:	0 Size:	65.0 KB ID:	440475
    cd40106 pin10 (main sample pulse width)
    Click image for larger version  Name:	3.jpg Views:	0 Size:	65.4 KB ID:	440476
    cd40106 pin 8 (Secondary sample delay)
    Click image for larger version  Name:	5.jpg Views:	0 Size:	70.1 KB ID:	440477
    cd40106 pin12 (Secondary sample pulse)
    Click image for larger version  Name:	4.jpg Views:	0 Size:	66.8 KB ID:	440478
    fly back
    Click image for larger version  Name:	6.jpg Views:	0 Size:	68.9 KB ID:	440479
    this video playing in damping resistor
    https://www.youtube.com/watch?v=EwLhewp3_fE
    THX FOR ANY HELP
    • You've posted a bunch of waveforms that have nothing to do with U2-pin6. What, exactly, is the problem? You can't adjust the output offset of U2?
      • was GND clemma of your o-scope probe connected to -12V of a schematic?
          yes i am trying to null offset to get 0v.
          -1.12v u2 pin6 don't change when turning r6
            or -5v
            sorry i didnt understand what you mean
            • Originally posted by Deghbar613 View Post
              or -5v
              then put YOUR schematic here be cause i do not see where you connect (-) probe wire to your board.
              2. WHY -5V?
                the schematic is geotech rev A
                i connect (-) probe to 0v
                https://www.geotech1.com/forums/foru...oject-Details=
                • Do you have the correct variable resistor value? And if yes, have you tried another 5534 IC chip? Or maybe you have a Chinese fake IC.
                    I am trying to get an other ICs maybe it's fake i didn't like outpute wave
                    so the problem is only from IC or r6 ?
                      is your o-scope in OPEN mode of the channel or CLOSE? i do not know how it is tell in English but Carl will help i hope.
                      anyway, put o-scope probe on -5V and after on +5V and do those pics for me.
                      • It's possible the NE5534 is a fake. Can you post the waveform on pin 6? Also double check the values of R6 and R8, and that R8 has a good connection to +5V.
                        Here is a more universal method of offset adjustment that will work with any opamp:
                          Click image for larger version  Name:	image.png Views:	3 Size:	12.6 KB ID:	440503
                          This is the waveform of ne5534 pin6 in video below
                          i am playing in damping resistor
                          • the horizontal part of the signal must be sure lie on X axis. is it clear?
                              Yes
                              i need to change ne5534 i think it's fake
                              the others waveform i posted are they ok ?
                                The response decay is way too slow. I suspect a fake opamp.
