darov922 or open to forum,
On this forum is a whole bunch of ideas what to use and not use in building a Minelab coils of any size. Plenty info for what type of litz or stranded tin wire and shielding. The big issue is the cable to the box. You loose all that you gain with perfect coil
if the cable has high resistance and capacitance. One says that he had the cable specially made litz 9 type cable. I have use Mogami cables with my PI coils in the past. This will not work with Minelab coils. The cost is one of the problems. Buying a spool litz 9 is cost prohibitive.
I wish I had the answer. Still looking. Anyone on the forum that has good info that can pin point exactly what to use for coil, shielding and cable to box for Minelab required numbers. Going to China is not the best because you have no idea of quality, fraud and time line. I guess
this is the problem in building your own coils. Minelab 10" mono coil starts at $250 and from there as much $1500 for a coil besides the detector $5000 to $8000. Moodz is attacking the box issue I think. Easy build for his MAGPI V3. More to come with V4.
