    Slow drift can be a symptom of two things.
    The differential amp is overloaded / railed .... the voltage at the oupuf of the differential amplifier U1 should be fairly constant at around 1 to 1.5 volts. If it is closer to 0 or 2.8 volts then the amplifier is seeing an offset current due to ..
    1. Leaky input capacitors ... the DC blocking caps must be high quality film caps C6 and C7. Even a very small leakage current will cause an offset DC votage that will rail the output. The integrator caps need to high quality too. Ceramic caps are way too leaky.
    2. Overload input ... the samples from the integrators R13, R14, C4, C5 are overloading the input to the amplifier. If the difference between voltage inputs exceeds 150 microvolt approx then the diff amp will overload. Bad sampling windows will do this.
    Hello. I assembled Magpi 3. The speaker produces a constant sound that disappears when the target is brought closer. If anyone has encountered something similar, please help. Sorry for my English
    • Originally posted by AhmatAhmatov1959 View Post
      Please post some photos of the board top and bottom and we will try to assist.
        Hello. Thank you for your reply. I replaced INA125 and it worked. I buy all the parts from ALI. The metal detector has a sensitivity of 20 cm on the hand. On ferrite 15 cm. On copper getinax 50-60 cm. The gold in the photo is compressed foil, it is not an ingot. 3-4 cm. The coil is homemade with a diameter of 20 cm. I made a rope from 44 insulated wires 24 meters long and 0.17 mm in diameter wound 26 turns, left 1 meter at the beginning and 1 meter at the end. The initial meter was wrapped with 10 layers of Teflon tape and put into a heat pipe, and on top I made a screen from the last meter, additionally added 5 wires to the screen for connection to the graphite screen. The Chinese tester showed 280 mcg, 0.4 Ohm and 850 kHz together with the cable, I thought that this was a good result. If of course the tester is not lying. I have several questions for you. 1 What to do with the voltage on the coil. 2 What transistor can replace the BSP230 for higher voltage. 3 How to reduce the influence of ferrite.
        I soldered a 120 pf capacitor parallel to the coil but did not notice any changes. Click image for larger version
ID:	437310 Click image for larger version
ID:	437311 Click image for larger version
ID:	437316 Click image for larger version
ID:	437313 Click image for larger version
ID:	437312 Click image for larger version
ID:	437315 Thank you very much for the provided project. I enjoyed making it. Before that I made a Tecoro Lobo, but after 3 unsuccessful coils I decided to do only pulse metal detectors.​
          Hello. Please help. The metal detector is very sensitive, it reacts to a hand, a wooden ruler, a plastic ruler at a distance of 20-30 cm. Which screen for the coil would be better, aluminum foil or graphite. If graphite, what resistance should be at a distance of 1 centimeter. The only change I made was the use of LM7171. Thank you
            If the coil is picking up your hand then most likely there is no faraday shielding on the coil.
            You can use graphite paint ( make your own out of a few drops of varnish mixed with acetone and large spoonful of graphite powder in a glass jar.)
            Lay down a very very thin copper wire connected to ground of the coil cable along the coil circumferance ( however do not connect the ends of the copper wire to form a loop !! )
            Paint the graphite mixture onto the coil in a thin continous coat ... but leave a gap ( eg 5 mm ) so no loop is formed.
            test and reapply graphite if necessary.
              Hello. Is it possible to connect a DD coil? There were no modifications for two years of the project? Thanks for the answer. Sorry for the English
              • Originally posted by Gunghouk View Post
                Hi Moodz, what is the latest version for LCD display ? If there is, any chance of a copy please ? I'm currently using 1.5 with non working volume.
                Hello. Please answer. Is it possible to connect a DD coil to this metal detector? If so, how. Thank you
                  Hi ... The MAGPI is a monocoil detector. Unfortunately you cannot connect a DD coil to the detector without modifying the code and a few hardware changes.
                  I am not saying its impossible but you would need to separate the RX circuit from the TX circuit and modify the timings.
                    Thanks for answering. I don't have enough brains to change the timings.
                      well I have an idea in the works .... it will improve things and you will be able to reuse the MAGPI circuit.
                      Might take a little while .... ( couple of months maybe or sooner if things work out ).
