Threshold Pot doesn't work
  • MartinB
    Originally posted by h9361 View Post
    yes, i put a gap.
    No, i did not re-nulling coil with shield.
    For re-nulling, do you think i should change number turn of buck coil?
    Might be a silly question, but did you connect the shield to ground?
  • h9361
    yes, i put a gap.
  • waltr
    Pictures of how the shield is done.
    Is there a gap to prevent eddy current within the shield?
    Did you try re-nulling the coils with the shield?
  • h9361
    Hello
    Dear Walter
    As you know, i have built a concentric coil.
    Today, i tried to add a shield (graphite or foil) to both inner and outer coil but i had a problem.
    As soon as connecting shield to ground (+B), my TP4 will be broken.
    This is TP4 without shield
    And this is with shield connection
    Do you think it's normal for concentric coil?
    Thank you.
  • waltr
    I use 3S LiPo with 1200 to 1800mA-Hr capacity.
    Is that 2200mAmp-Hour capacity? If so then simply divide that by average current draw.
    2200/100 = 22 hours but divide in half to be safe for the Li (they die if over discharged) so easily 11 hours of operation.
  • h9361
    Hello
    Dear Walter
    Please forgive me for my questions.
    Can you tell me your battery amperage and maximum hour that you had experienced?
    As you know, HHD consuming is approximately 100mA.
    I'm going to series three 3.7V-2200mA batteries, but i can't estimate its maximum hour for continuous working.
  • waltr
    Hello
    Dear Walter
    I have a question about your experience with concentric/DD coil.
    Can you tell me what type cable you used between coil and unit? For exp, Microphone ?!
    For my PI detector I use CAT5E cable.
  • h9361
    Hello
    Dear Walter
  • h9361
    Thanks dear Carl and Kt315.
  • Carl-NC
    Correct.
  • kt315
    I think your means is that, is it correct?
    [ATTACH]58198[/ATTACH]
    look Delta Pulse VU meter resistor connected. a 'snow' sign is meant 'tuned value'.
  • h9361
  • Carl-NC
    No, across the meter terminals, not in series.
  • h9361
    Increase the value of R36 (the one that drives the meter) until it does what you want. You might also need a resistor in parallel with the meter, I would start with 10k.
    Thanks dear Carl.
    Please see attached, do you think position of the 10K is correct?
  • Carl-NC
