This makes much more sense, and as you probably understand very well this far from being nanovolts. Incidentally, I got an advertisement the other day to buy a Keithley voltmeter and they proudly claimed 6 and a half digits!Originally posted by Aziz View PostHi gwzd,
I made some numerical tests with the input data now. The noise is typically on the least 4-6 significant bits of the 24 bit input data.
Very true, the easiest and most reliable measurements are the differential ones not the absolute ones. The latest required frequent calibration and very narrow set of conditions.Originally posted by Qiaozhi View PostSo what does all of this tell you? ... that you should be measuring relative, not absolute changes in the signal, and tracking the signal drift over time.
No electronics! I like that, sounds kind of like dowsing, but then again, those fellows have become "high tech" also.Originally posted by Aziz View Postyou all will be very surprized, when I am going to show you, that the laptop detector will also work very well with only conntected coil without any electronics.
What they have discovered is a lousy temperature compensated oscillator.Originally posted by simonbaker View PostNote: you discovered why all coil covers should be white to keep as cool as possible so less change when you swing in and out of shadows. Tesoro makes a black coil, I think a no-no.
Hi gwzd,Originally posted by gwzd View PostNo, it is not
nice to hear from you again. By the way, the neighbor's daughter is allways the reason for us, to get
- bankrupted
- totally diseased
- and preventing us to work further.
This was my own bad experience in this case. Be awared!
How you would do the synchronisation to an external oscillator?
With locked injection method?
Aziz
No external electronics. All the electronics is provided by the laptop itself. And the software will do the rest.Originally posted by gwzd View PostNo electronics! I like that, sounds kind of like dowsing, but then again, those fellows have become "high tech" also.
I do not believe in dowsing.
Hello Aziz,
Tons of work, we are releasing in august a new GPR with a couple of new antennas and its getting tough with the time schedule.Originally posted by Aziz View PostHi gwzd,
You haven't seen her, so let me tell you, when I finally get her I will not be very worry about bankruptcy or disease, leave alone work!By the way, the neighbor's daughter is allways the reason for us, to get
- bankrupted
- totally diseased
Simply, use a PLL or any kind of closed system that allows you to keep track on what's going on.How you would do the synchronisation to an external oscillator?
Aziz
Hi guys,
some experiments with forced resonant mode, where the TX coil is driven with the reference clock from the laptop, has some disadvantages on discrimination possibilities. The phase shift can not be used clearly to distinguish between ferro-magnetic and dia-magnetic materials. In contrast to this, an all metal mode is much better to use with high depth sensitivity. However, this could be used for preferred prospecting mode.
For a better discrimination, an external LC oscillator is much more convenient. The frequency and the phase shift occures in the direction, where a correct discrimination is possible. I will try to lock-on to an external LC oscillator, where some drifts in phase and frequency will be compensated in a defined time constant.
Aziz
Hi Aziz
I make experiments with phase shifting +/- 0.5 deg at 12500Hz
between Tx / Rx and between Inphase and Quadrature parts
Real, I have two demodulators in one chip - this is only for tests - I looking best solution for MCU/DSP based MD
You raise a question I have had about some metal detector circuits. I often see that the TX coil is part of the oscillator, rather than being driven by a separate oscillator through a buffer amp.Originally posted by Aziz View PostHi guys,
Aziz
My question is: which is better for measuring phase shift in the RX coil -- 1) TX coil is part of oscillator, or 2) TX coil driven by separate uncoupled oscillator, with the separate oscillator used to as a reference to measure phase shift in the RX coil.
I thought that maybe a target in the ground would shift the phase of both the TX and RX coil in the same direction, so the difference would be less, and harder to measure. But if a separate oscillator were used that is not affected by the target, the phase difference would be larger and easier to measure.
Your experiment seems to indicate that (1) is better.
Would you explain more about what you have found?
"Let's make a PC-based metal detector with usb interface!!!
Hello George ,Welcome to the forum .And the answer to your question is "Closer than Ever" The reason is , In just a few years ,the number of Electronic Technician's and Electronic Engineer's who have joined the "GEOTECH FORUM" has Doubled or Tripled. I do not have the numbers. On the "Design idea" thread, stuff is normally being posted daily,and we are very close to some "breakthrough-designs". Also when there is a Technical Problem or any Metal detector question it usually get's answered within a day....Be patient ,the Forum Members we have here , are "The Best of the Best" from around the world !!!........Take care.......EugeneOriginally posted by george boswell View PostHow many years are you people from making something that will work as good as a real metal detector? Just a guess will work.
