TF-900_TM800
  • Click image for larger version  Name:	switch.png Views:	0 Size:	99.2 KB ID:	412449
Name:	CROSS POINT.png
    Click image for larger version  Name:	TF900 pcb all.jpg Views:	0 Size:	828.7 KB ID:	412450
    • Pcb based on Ivconic model
      • Corrected (I think...
        • Hi,
          Could this 4P3T + 1 switch power on/off serve? :
Name:	ROTARY SWITCH.png
          • Looks like a 3 Pole, 4 Position rotary switch. No additional contacts for power.
            • Only S4 Power on / off, (top-right)
              I think it will work properly ..., I hope
              PCB before the last revision :
Name:	TM00 PCB ALL.jpg
              • Hi,
                A possible correction in 3638 emitter -> 4R7 and 10k resistors :...:
                PCB Ivconic
                Click image for larger version  Name:	PCB IV 3638.png Views:	0 Size:	124.7 KB ID:	412561
                Scheme
                Click image for larger version  Name:	TM800 SCHEME.png Views:	0 Size:	81.0 KB ID:	412562
                Correctión ?
                Click image for larger version  Name:	PCB BERRE 3638.png Views:	0 Size:	247.4 KB ID:	412563
                • An other correction :
                  R43 - 6k8 to REF OUT :
Name:	R43 6K8 FLT OUT SCHEME.png
                  PCB Ivconic 6k8 -> 220R (+9v)
Name:	PCB R43 6K8 FLT OUT.png
                  • Solution to R43 6k8 to > FLT OUT
Name:	R43 6K8 FLT OUT.png
                    • Better, I leave pcb like this, and after testing, if R43 goes to FLT OUT or VCC1, it can be easily modified
Name:	R43 6K8 FLT OUT OR VCC1.png
                      • Finished ! :
                        TM800 PCB ALL.pdf
                        • Hi berreizeta
                          Have you finished making Tf900? And please announce the results. Thank you​
                          • Hi to all. If anyone has completed this project, please post the results here. Tanks
                            • It's amazing how distracted and lost I am!
                              I'm working intensively on one device, I'm all "fired up" about it.
                              And then something else caught my attention and I left what I was doing "for a moment".
                              And that "for a moment" can take months and sometimes years in my case!!!
                              This work is sitting on the shelf, all dusty, my cats use it for various stunts...
                              and all that's left to finally finish is to solder the connectors to the cables!!!
                              Yes, it has been successfully completed and is working well in workshop tests.
                              If only one of you would come and solder the connectors...
                              Click image for larger version  Name:	20230909_090409.jpg Views:	0 Size:	389.1 KB ID:	415044Click image for larger version  Name:	20230909_090430.jpg Views:	0 Size:	203.7 KB ID:	415045
                              Click image for larger version  Name:	20230909_090455.jpg Views:	0 Size:	489.8 KB ID:	415046Click image for larger version  Name:	20230909_090459.jpg Views:	0 Size:	267.3 KB ID:	415047
                              • Nice job, done... even the Whites Logo looks cool!
