@ Gandolfi,,,,This is a working pcb,,,If you load it into Sprint Layout you will be able to export the Gerber files from it. MartyAttached Files
hi,
My detector is dead....
Anyone have GERBER file for the PCB ?
thanks
meybe its a weak from short secret and burned with a high pulse more than 200 or meybe bad connection coil cable and suddenly dissconnected or from touch hand many thing
what burn again
work good for some time and then start coil error change lf357n the same error what burn this time.
felezjoo PI(the best pulse induction metal detector copied from the russian site , just visit the and made a unlimited HEX free detector
https://acdc.foxylab.com/node/47
- Likes 1
Dear All , Any update regarding full working HEX , Owner of this detector didn't respond , with out full HEX project is incomplete
- Likes 1
Yes in resistor I have 9.50 but I change two ic and i have the same error
if you have 9.50v on this resister its mean ok 18k just change ic with another brandand press down should this msg gone
Arionas - I have deleted the huge amount of text you attached to your post, as it was seriously slowing down the forum.Originally posted by Arionas View PostFelezJoo_PI_v3_35
If you want to attach hex code, then compress it as zip and attach it as you would any other file.
