    and how would this work with a 4*18650 holder and one step down modul
    should be more efficient and less weight then lead gel
    My new board runs on 18650 battwry pack 12v without l7812 and 22k is change with variable resistor which settle at 15.6k. I think it is more efficient than using converter and regulator.
    • Originally posted by mickstv View Post
      Hi jladre, could you please post a CRO picture of what your seeing on the output of the preamp IC, using the coil from the YouTube clip.
      Mick
      Hi mickstv.. Maybe i can take a photo on it when i can barrow again my friend oscope.
      • About the coil I will share the design when I have the material to build another one because previous coil is totally sealed.
        Hi jladre, if you do not have enough wire, for demonstration purposes you could wind the coil with string or fishing line just to show your winding method .
          your speaker looks like from old dvd player?
          Yeah..hehehhe I couldn't find any small speaker 2watt 8 Ohms speaker I try buzzer but not good, I try speaker from TV it works ok and so loud but bulky.
          • Can the cable to the probe?
            View results and find madison awm 20276 datasheets and circuit and application notes in pdf format.
            Best Regards
            • hi all
              I like to know the location of 1N5819 on the map
              thank for all
              • This diode isn't necessary, so not on the board.
                • Originally posted by chevesne View Post
                  thank you
                  • Originally posted by reptooyep View Post
                    I'm realy interrested into your owashima soft, could you share a domnload link please, i tryed everything but my reasearch does not give any result...
                    I believe in the US, this is the Oshonsoft AVR Simulator. Looks to be the same software IMO, and a nice little tool. Strange about the different author naming though.
                    It's not free, but you can get it at www.oshonsoft.com. The download has a time restriction. After it expires, you will need a license key. They also offer simulators for other processors there too (PIC, Z80, 8085, etc) as well as some other useful software.
                    Anyway, there it is if anyone is interested.
                    B
                    • hi all
                      i have charged 3.30 version
                      Screen displays:ainise/0.3f/powef
                      help please
                      • HI ALL
                        hi friends
                        I will like to know how I can load ATmega328 with Arduino uno?
                        I had written myself but load on the display DEMO !!!
                        thank you for all
                        • Comment
                          • hi friend. perfect deep.
                            • Hi. Frind. Do you have full versiyon hex. Which you can in your hands.
                              My mail. [email protected]
                              • Hi
Name:	felezoo pi key.jpg
