Hello, someone knows how to edit the detector's start, instead of saying "felezjoo pi" say my name?
Hi all,,,I have made 5 successful Felezjoos up to now and find that the best voltage is 18v,,,I use 3 x 18650 with a buck converter to boost it from 12v to 18v and it lasts me about 5-6 hours detecting time,,also, I have no problems (Touch wood), up till present using a 300uh 2.5 ohm 3dss coil with either of the 5 builds,,,they all work equally as good as each other. Regards,,,Marty
Boost converter.Originally posted by MartyJ1963 View PostHi all,,,I have made 5 successful Felezjoos up to now and find that the best voltage is 18v,,,I use 3 x 18650 with a buck converter to boost it from 12v to 18v and it lasts me about 5-6 hours detecting time,,also, I have no problems (Touch wood), up till present using a 300uh 2.5 ohm 3dss coil with either of the 5 builds,,,they all work equally as good as each other. Regards,,,Marty
@Dbanner,,Cheers,,yes, it's a boost converter, my mistake. @Sabios,,,yes, you can use the one in your photo,,that's the same one I use. I use mine with 3 x 18650,,each battery of mne has 3600mah,,but recently I used 4500mah and it lasts much longer,,8-10 hours,,plenty enough for a day out. Regards,,Marty
- Likes 1
Hello guys
Want to try this PI..I see there are lots of pages about this in this thread and as i can tell the final version of this pi is 3.30...It has some locking feature i dont really mind but is its descrimination works??I saw 2-3 different PCBs on this thread can someone direct me to a correct one?Or if by any chance there is a project file (schematic + BOM)..Ive downloaded 2 files i dont know if they are correct
- Likes 1
