The coil resistance should not be 0 ohms, rather 0.5 ohms or more. This is just a check if the coil is not shorted = 0 ohm.
But then you would get the 'coil error sound' = no flyback pulses detected.
To put evertything on a timeline - please correct me if this is wrong:
- you have built this PCB, connected a coil and everything worked fine ? Normal detection sensitivity ?
- some time later, the sensitivity has decreased ?
Can you check on pin 3 of the PIC16F1824 if the sensitivity setting is changing between 0 and 5V when you turn the sensitivity potmeter ?
Also check the capacitor that is in parallel with the 1M feedback resistor of the opamp LM318. It should not be more than 4.7 pF.
You can even remove this capacitor.
Also check all DC voltages with a multimeter on each pin of the microcontroller and the opamp:
The reference voltages are here:
