Delta Pulse - Take 2
    i can send file to file, if you so ask. i did that billion times in the forum. a schematic.VERY PLEASE do not ask me frequency's choice be cause it is at the sch WRITTEN-NOTED. Click image for larger version Name:	dp_sch5.jpg Views:	0 Size:	826.8 KB ID:	439658
    Hi, I managed 73% of the 6.4gig download today a record then it crashed again. Anything that is relevant to building a successful Delta Pulse Legend Rev5 would be great.
    Advice from an expert in finding stuff, simplify and focus.
    • A new rule, no boards to be sold without BUILDING DOCUMENTS✌
      • BOM file
        • Originally posted by Infamy View Post
          If you need a building documents for a DIY project you should build the Hammerhead, Barracuda or MiniPuls Project. Or watch the assembly videos for Crossbow, SurfPI etc. on YouTube.
          • i can give HOW TO MAKE SPEEDY DELTA AND GET SURE MAGIC SMOKE document. although for turkish board, but it's same.
              BOM file
              Failed to download.
                Failed to down load
                Found it on idoc.
                Is there anything to add to that, it is the sort of doc I was looking for.
                  Seen the videos. I don't want to loose my hair in already known traps holes or other place . Thanks
                    Failed to download.
                    Hmm,
                    there must be something wrong with your Internet connection. I was able to download the BOM file as well as the "...GET SURE MAGIC SMOKE..." document. Both documents i can open. .
                    • Hello Infany,
                      What are you looking for for the Deltapulse project? Everything you need to assemble and complete the Deltapulse project can be found here. Have you seen my post #216? It basically contains everything you need for the project. When I built the Deltapulse over 20 years ago, I only had the deltapulse schematic and nothing else, and was able to build a working detector from scratch since no circuit board was available back then. The schematic posted by KT315 is even better and more detailed than the old schematic I had when I created the project.​
                      This is the circuit diagram I had when I assembled the Deltapulse.
                      • I managed to download KT315's huge archive of 6.4GB in about 8 minutes.
                        Only one folder in the RAR file applies to Deltapulse. If it's a Build Document that you're looking for (similar to MiniPulse), then there isn't one.
                        • Okay thanks.
                            Failed to down load
                            Found it on idoc.
                            just folder with DP. i think your connection to internet is very poor. https://drive.google.com/file/d/12KK...usp=drive_link
                              Thanks for the folder. Connection poor probably. On the multiple choice for parts any suggestions as to one be better than another? Any suggestions on those resistors with 1% or better tolerances? You know I'm probably going to ask you what has been asked many times before, maybe that is the purpose of no build document?
                              • first of all you have to sold sound part (on NE555) and check it. 99% of all problems is this part.
