That sounds fun. I have some of those via Ebay china, maybe I'll source some through Farnell.
Delta Pulse - Take 2
Instructions How To Make Delta Pulse Working. Following Steps.
PleaseleavedrinkingoffintimeyoumakeDP.
Pleasedo not use resistors of 0.5Watt of power. Theboardisfittingonly0.125or0.25Wattresistors. You can use 0.075 Watt resistors too.
R5andR6take 0.5,1.0or2.0Wattresistors.
Pleasecheckallresistorsbymeasuring,beforeyousolder . Another way you get big trouble.
Checkalsoall diodesbyatester,beforeyousolder.
CheckallelectrolyticcapacitorsbyESRorLRCtester, beforeyou solder.
SolderallIC’sandcomponents,besideIRF740.Solderapin intest point –E (marked at PCB like =E).
Cleantheboardbyalcohol.
Setpotsinpre-setposition:
DEPTH-min,atleftside,counter-clockwise
DISC-min,atleft,counter-clockwise
GEB-middle
SENS-middle
T/HOLD-middle
Turntheboardto+12Vpowersupply.
You know what gets me is when I read about "the fool put all the components in the board" and now here comes on here and wonders why it aint working.
Delta Pulse PI metal detector. 1 stage. Sound checking. Проверка звука.
1) Please Sir can I have some more like all the stages?
op amp op-amp opamp and comparator LM339 LM393 tester
2a) Is this for sale with instructions?
2b) Do you have any other testing kit for sale?
3) The second board I have for the battery? instructions parts list photo anything so I know what it does.
4) I noticed you have a tendency to use ceramics where others don't, does this not give you resonance problems?
5) LM556 gives more detail than NE556 is that correct? I ask because I analyse the signals after survey, in post processing.
6) A description of what the following actually do would be interesting like depth for example, which components and what is adjusted
GEB-middle
SENS-middle
T/HOLD-middle
7)" Solder all IC’s and components, beside IRF740", poor IRF740 does it every make it to the board, what did it do wrong?
The next time some one comes on here with a problem and has stuck all the components on the board with out testing different sections of the board, think for a moment is this a Geotech1 problem, like lack of a manual !!!!!!!!!!!!!!!!!!!!!!
PS do you have anymore Delta Pulse rev 5 boards for sale?
- Likes 1
you may test the sound with all components in board and without all with just sound NE555. you have to sure present as NE555 works in standart connection.
if not...
I had got billion of complains 'no sound'. and yes I do not know why the people have this problem. so I did two videos to SHOW VISUALLY in youtube how to test the sound because simplest text is not understandable for the people. the roof is sure first.Originally posted by GeoMax View PostWhy would someone start with the sound system first? That doesn't make sense. It's like starting with the roof when building a house.
Originally posted by Detectorist#1 View PostHi kt315,
There is no possibility of giving useful advice when the level of knowledge of the recipients is to far from adequate.
I think they are learning Electronics Basic ABC Delta Pulse soldering... anyway the Magic Smoke is very well Teacher.Last edited by kt315; 08-19-2025, 06:49 AM.
You know I'm researching a book and I'm just trying to understand the animosity element of this detecting world, to people wanting to understand. Thanks for your contribution.Originally posted by Detectorist#1 View PostHi kt315,
Originally posted by kt315 View PostI think they are learning Electronics Basic ABC Delta Pulse soldering... anyway the Magic Smoke is very well Teacher.
Minelab has loads of insincerity maybe they have an opening for you?
You make a statement somewhere about detecting for all (logo?), you sell boards, you don't give them away and you won't provide a proper construction manual, what the story here?
I think I raised 8 points and you failed to answer any of them.
eg why do you sell some boards stuffed with ceramic caps, not very good design is it?
LM556, do you know the answer?
In modern super fast track construction many elements can be happening at the same time? Build the roof on the ground then lift it in place with cranes.Originally posted by GeoMax View PostWhy would someone start with the sound system first? That doesn't make sense. It's like starting with the roof when building a house.
Advantages fast and safer than working at height. Less saftey equipment needed.
This place seem like its stuck in a rut and unable to see from different angles.
Carl is working on First Texas, it's enough
I do NOT sell the boards, I HELP geotechers to do right things. sometimes. BTW you do not want to show your soldered board, why?
sorry, just 1 point in a day i can answer. if i will give you the Manual and answer on your all requests this topic will soon be closed. while this topic is GREAT and must be open.
just you deep delusion. indicating me that you are at beginner stage. anyway, DP is good learning platform in PI methode.
As I have said a few times when referring to the construction of a particular metal detector project:
Do not simply populate the whole board; discover it doesn't work (which will be the most likely result) and then post in the forums: "I've built the [whatever detector it is] and it's not working. What's wrong? ..... as you will receive little sympathy from the Geotech members.
- Likes 1
If you don't sell boards then should I be expecting a refund?Originally posted by kt315 View PostMinelab has loads of insincerity maybe they have an opening for you?
Maybe you could explain why Dacs from the 1980s such as 1540 1541 when used in high end audio avoided using ceramics.
You fail to answer the question throw out an insult, delusional. Maybe you are ripping people off who don't question boards you sell stacked with poor quality components.
If its not a bad choice explain why.
For some one who does not give out proper information with the product they sell, that's you, its a ****ty way of doing business relying on others to finish the job fill in the blanks. Garret don't sell detectors and say if you want instruction look on a Minelab website do they. I'm working my way through that 4000s post link you gave and you moaning non stop as if this is the main feature of your life. Well I think I've stayed long enough in Geotech1 crap land
